Technical Forum
Custom Alert Banner
iRULE for SSL2WAYS, Client certificate verificaiton
FaresB
Hello,
I have an iRULE to check if client certificate is OK, the check is on the CN and there is a verification to check if the client certificate's authority is known by the f5.
Here is the iRULE , is there any error in this iRULE ?
when CLIENTSSL_CLIENTCERT {
           # Check if there is a client cert
           set error_page 0
           if {[SSL::cert count] > 0}{
                       # Check if there was no error in validating the client cert against LTM's server cert
                       if { [SSL::verify_result] == 0 }{
                                   log local0. "Client Certificate is validated by CA Bundle"
                                   set cert [SSL::cert 0]
                                   set CN [getfield [getfield [X509::subject $cert] "CN=" 2] "," 1]
                                   log local0. "The CN is: $CN"
                                   set subject [string tolower $CN]
                                   log local0. "The CN in lower case is: $subject"
                                   if { (($subject equals "mysiteA.fr")||($subject contains "mysiteB.fr")||($subject equals "mysiteC.fr")||($subject contains "cn=mysiteD.fr"))
                                              log local0. "Client certificate matches the list of authorized CNs"
                                              return
                                              set error_string "CN not valid"
                                              set error_page 1
                                              log local0. "$error_string"
                                   set error_string "Client certificate provided not validated by CA Bundle"
                                   set error_page 1
                       set error_string "No Certificate"
   if {$error_page}{
       HTTP::respond 403 content "<html>Invalid client certificate: $error_string</html>"
1 REPLY 1
FaresB
Hello,
The problem is in the IF condition to check CNs , there is too much ÒR conditions.
Please can you help me to replace IF condition using a string datagroup :
   if {($subject contains MyDataGroup)
is it right ?
