iRule for HTTP per request balancing
andrey_k_112670
Hello iRules Experts,
I'm very new to iRules, hope you may help me with clarification.
I'm a bit confused with the correct event triggers processing to perform the following task:
1. The Virtual Server is balancing SOAP requests to two nodes.
2. Usually it would be one persistant http/tcp session established from the client side.
3. SOAP request must be balanced based stricly on the SOAP body contents condition to the correct node.
Here is my first iRule, which does not work (drop the tcp session):
rule rp50_rule {
when CLIENT_ACCEPTED {
set NODE1 198.19.0.49
set NODE2 198.19.0.55
if { [HTTP::payload[] matches_regex "380\d{8}[02468]@.*" } {
pool radius5016_pool member $NODE1 8081
log local0. "sending rp50 to: $NODE1"
else {
pool radius5016_pool member $NODE2 8081
log local0. "sending rp50 to: $NODE2"
virtual rp50_vs {
destination 10.2.97.229:8081
ip protocol tcp
profile http tcp
rule rp50_rule
vlans external_mobile enable
pool radius5016_pool {
monitor all gateway_icmp
member 198.18.0.49:any
member 198.18.0.55:any
AFAIU, the pool is per connection balanced. What events should I intercept and force the BIGIP to establish two tcp sessions?
thank you,
- andrey
2 REPLIES 2
Harel_115646
Did you find an answer?
Vijay_E
Altocumulus
Altocumulus
If you just want to load balance per HTTP Request instead of the default per TCP connection, use OneConnect with /32 netmask.
Avoid using regex within iRule as it tends to consume more resources in the F5.
