Technical Forum
IRule for Exact resource access rejection
NetWork
I would like to know the feasibility of implementing iRules for below scenario, kindly suggest whether it is achievable or not.
https://my.domain.com/mrj/home/srt/portal/prtroot/com.dev.net.sendemail >> only request to this resource should get rejected
https://my.domain.com/mrj/home/srt/portal/prtroot/* >> other should get allowed
1 ACCEPTED SOLUTION
Hello NetWork.
Actually the previous sentence has a mistake. It should be like this.
set uri [getfield [HTTP::uri] "?" 1]
This is used to remove de Query parameter of the URI. For example if you receive something like this:
/mrj/home/srt/portal/prtroot/com.dev.net.sendemail?myuser=john
Taking into account that you need to reject any URI related with
/mrj/home/srt/portal/prtroot/com.dev.net.sendemail*
Then you should use "starts_with" instead of "ends_with", and the sentence before would not be necessary.
Your iRule should be like this:
	if { [HTTP::uri] == "/" } { HTTP::redirect "http://[HTTP::host]/mrj" }
	elseif { [string tolower [HTTP::uri]] starts_with "/mrj/home/srt/portal/prtroot/com.dev.net.sendemail" } { reject }
	elseif { [string tolower [HTTP::uri]] starts_with "/mrj" or [string tolower [HTTP::uri]] starts_with "/web" or [string tolower [HTTP::uri]] starts_with "/htmlb" } { pool pool-A }
	elseif { [string tolower [HTTP::uri]] starts_with "/abc" } { pool pool-B }
	elseif { [string tolower [HTTP::uri]] starts_with "/" } {reject}
Please, if this was helpful don't forget to mark my answer as 'the best' to help me for the contribution.
Regards,
Dario.
Regards,
Dario.
4 REPLIES 4
Hello NetWork.
Yes, it's feasible. Try this:
	set uri [getfield [HTTP::uri] "?" 2]
	if { $uri ends_with "/mrj/home/srt/portal/prtroot/com.dev.net.sendemail" } { reject }
Regards,
Dario.
Regards,
Dario.
Hi Dario,
Thanks a lot for your response!
Below is our existing and working iRule:
     { pool pool-A }
     { pool pool-B }
     {reject}
If we modify it as below, will it work?
elseif { $uri ends_with "/mrj/home/srt/portal/prtroot/com.dev.net.sendemail" }
    { reject }
     { pool pool-A }
     { pool pool-B }
     {reject}
Also, can you please help to understand why we need to put "2" in set uri [getfield [HTTP::uri] "?" 2] ??
And, in case if we want to reject anything after sendemail i.e /mrj/home/srt/portal/prtroot/com.dev.net.sendemail*, how that can be achieved.
Hello NetWork.
Regards,
Dario.
Regards,
Dario.
NetWork
Hi Dario,
We have tested in our customer environment, it works as expected.
Many thanks for your help!
