08-Sep-2020 05:16
Hi can some explain what the following Irule is looking to do
when CLIENTSSL_CLIENTCERT {
if { [SSL::cert 0] ne "" }{
if { not [class match -- [X509::subject [SSL::cert 0]] contains [virtual name]_cert_dgl] } {
reject
} else { reject }
thanks
Andrew
08-Sep-2020 06:24
in brief, this irules checks the CN of the X509 certificate in order to verify if it's present in the DataGroup [virtual name]_cert_dg , if not compliant it rejects the call.
More details here :
https://clouddocs.f5.com/api/irules/X509__subject.html
https://clouddocs.f5.com/api/irules/SSL__cert.html
Regards
