Technical Forum
iRule cookie persistence and pool redirect
Neo_Ph
Hi all, base on the on below setup...
  • When Pool A/NodeA1 goes down, we expect URI /beta/ requests to be sent to Pool B, as nodeA2 can't accept URI /beta/ requests.
  • However, when Pool A/NodeA1 goes down, we see the LTM sending URI /beta/ requests to Pool A/nodeA2.
  • F5 support said cookies have precedence over iRule and the cookie will try to honor it's persistence, hence why traffic is still being sent to Pool A / nodeA2(A1 is down at that point).
Strangely in lab I have a different behavior from the LTM.  Whether it's an new or a subsequent request, the source_addr persistence record will show the connection for 3mins(default timeout value).  During that time pressing F5 and CTRL-F5 will force the client's browser to reinitiate the communication.   When I reinitiate, despite having received a cookie, previously, for Pool A / nodeA1 -- I also get a new cookie for Pool B / node B1 and connect to node B1 successfully.  That behavior is what I'm expecting in production, but that's not the case.
Should I be adding more to the iRule, in order to maninpulate the cookies, or any suggestions of what can be at cause?
SETUP
LTM contains:
- cookie persistence with fallback source_addr
- Pool A with member nodeA1(priority 15 ) & nodeA2(priority 5); with min-active 1
- Pool B with member NodeB1 only
nodeA1 = 10.10.10.1
nodeA2 = 10.10.10.2
nodeB1 = 10.20.20.21
And an iRule that should mainly redirect like this:
if { PoolA/nodeA1 is down + URI equal "/beta/"} {
         then send it to Pool B
else { send it to Pool A }
Here is the iRule:
set sslex 0
if { ([string tolower [HTTP::uri]] starts_with "/beta/") && ([LB::status pool Alpha-Pool member 10.10.10.1 443] eq "down") } {
set sslex 1
set sni_value "betaServer.lab.com"
HTTP::header replace Host "betaServer.lab.com"
set uri [string map -nocase {"/beta /" "/"} [HTTP::uri]]
HTTP::uri $uri
pool Beta-Pool
set sslex 0
set sni_value "lab.com"
pool Alpha-Pool
when SERVERSSL_CLIENTHELLO_SEND {
# SNI extension record as defined in RFC 3546/3.1
# https://support.f5.com/csp/article/K41600007
if { $sslex > 0 } {
SSL::extensions insert [binary format SSScSa* 0 [expr { [set sni_length [string length $sni_value]] + 5 }] [expr { $sni_length + 3 }] 0 $sni_length $sni_value]
2 REPLIES 2
AlexBCT
MVP
MVP
Hi Neo_Ph,
Seen that you get different behaviour in the lab as in live, that's interesting indeed! Have you gone through the virtual server configuration to ensure that they are exactly the same? Especially the profiles?
Also, can you check that the iRules in the live and lab systems are attached in the same order? (order very much matters when it comes to attaching iRules under the Resource tab)
And are there any other differences either in software or configuration between the live and lab systems?
There are a few differences such as the use of F5-TCP-WAN & F5-TCP-LAN in the lab, instead of just using tcp profile.  There is only 1 iRule. But the major difference would be the lab version at 13.x vs Prod at 15.x.
I will have to upgrade to version 15.x and redo my tests. And also use the same profiles, just in case it would impact the way cookie persistence is operating; which would surprise me. I'll add an update afterwards.  Thanks AlexBCT
