Irule Clubbing due to TCL errors.
StephenGonsalv1
Hi Guys,
Need help to combine these irules.
Code
when HTTP_REQUEST { set http_uri [string tolower [HTTP::uri]] switch -glob ${http_uri} { "/ib/*" { } "/robots.txt" { } "/favicon.ico" { } "/rsabackchannel/hbibservice.svc" { if { [class match [IP::client_addr] equals FynSin_IPs] } { } else { HTTP::respond 301 noserver Location "; } } default { HTTP::respond 301 noserver Location "; } }
when HTTP_REQUEST { set version [SSL::cipher version] set cipher [SSL::cipher name] set oldsite [HTTP::host] set encode [b64encode $oldsite] Check for less than TLSv1.2. This prevents SSLv2, SSLv3, TLSv1, and TLSv1.1 (TLSv1.0 is returned as TLSv1 by [SSL::cipher version]). switch -glob $version { "TLSv1.2" { do nothting } default { When browser cannot negotiate at least TLSv1.1 redirect to a unencrypted page with an informational error. Set cache control headers to prevent proxies from caching the response. The cache control headers shouldn't be necessary for a 302, but it doesn't do any harm setting them. HTTP::respond 302 Location "http://y.y.y.y.com/?$encode" Cache-Control No-Cache Pragma No-Cache Connection Close
Log details of the SSL handshake and browser user-agent Consider using High Speed Logging instead to improve performance: https://devcentral.f5.com/wiki/iRules.hsl.ashx log local0. "[IP::client_addr]:[TCP::client_port]:\ \[SSL::cipher version\]: [SSL::cipher version],\ \[SSL::cipher name\]: [SSL::cipher name],\ \[SSL::cipher bits\]: [SSL::cipher bits],\ U-A: [HTTP::header User-Agent]" } }
Cheers Steve
3 REPLIES 3
JG
Cumulonimbus
Cumulonimbus
Here you are:
when HTTP_REQUEST { set version [SSL::cipher version] set cipher [SSL::cipher name] set oldsite [HTTP::host] set encode [b64encode $oldsite] Check for less than TLSv1.2. This prevents SSLv2, SSLv3, TLSv1, and TLSv1.1 (TLSv1.0 is returned as TLSv1 by [SSL::cipher version]). switch -glob $version { "TLSv1.2" { do nothing } default { When browser cannot negotiate at least TLSv1.2 redirect to an unencrypted page with an informational error. Set cache control headers to prevent proxies from caching the response. The cache control headers shouldn't be necessary for a 302, but it doesn't do any harm setting them. HTTP::respond 302 Location "http://y.y.y.y.com/?$encode" Cache-Control No-Cache Pragma No-Cache Connection Close Log details of the SSL handshake and browser user-agent Consider using High Speed Logging instead to improve performance: https://devcentral.f5.com/wiki/iRules.hsl.ashx log local0. "[IP::client_addr]:[TCP::client_port]:\ \[SSL::cipher version\]: [SSL::cipher version],\ \[SSL::cipher name\]: [SSL::cipher name],\ \[SSL::cipher bits\]: [SSL::cipher bits],\ U-A: [HTTP::header User-Agent]" } } set http_uri [string tolower [HTTP::uri]] switch -glob ${http_uri} { "/ib/*" { do nothing } "/robots.txt" { do nothing } "/favicon.ico" { do nothing } "/rsabackchannel/hbibservice.svc" { if { [class match [IP::client_addr] equals FynSin_IPs] } { do nothing } else { HTTP::respond 301 noserver Location "https://x.x.x.x.com" return } "/sitecore*" } { HTTP::respond 301 Location "https://[HTTP::host]" Connection Close return } default { HTTP::respond 301 noserver Location "https://x.x.x.x.com"; } } }
StephenGonsalv1
Code ` Still seeing the following TCL errors TCL error: /EXT/I_TLS_Redirect - Operation not supported. Multiple redirect/respond invocations not allowed (line 1) invoked from within "HTTP::respond 302 Location "[http://obsolete.heritage.com.au/?](http://y.y.y.y.com/?)$encode" Cache-Control No-Cache Pragma No-Cache Connection Close" ("default" arm line 7) invoked from within "switch -glob $version { "TLSv1.2" { do nothting } default { When browser cannot negotiate at least TLSv1.1 redirect to a unen..." Following are the I rules 1) when CACHE_RESPONSE { CACHE::expire } when HTTP_RESPONSE { Remove all instances of the Server header HTTP::header remove Server Remove all headers starting with x- (i.e. X-Powered-By, X-AspNet-Version, X-AspNetMvc-Version) foreach header_name [HTTP::header names] { if {[string match -nocase x-* $header_name]}{ HTTP::header remove $header_name } } } 2) when HTTP_REQUEST { if { [string tolower [HTTP::uri]] starts_with "/sitecore" } { HTTP::respond 301 Location "https://[HTTP::host]" } } (need to add the following to this following to this request) Any hit to [https://x.x.x.x.com/](https://x.x.x.x.com/)[URIPATH] to do a 301 permanent redirect to [https://wwwx.x.x.x.com.au/](https://wwwx.x.x.x.com.au/)[URIPATH] ======================================================= 3) when CLIENT_ACCEPTED { set static::expires [clock scan "1 year"] } when HTTP_RESPONSE { if { [IP::client_addr] starts_with 10. } { } else { HTTP::header insert Strict-Transport-Security "max-age=[expr {$static::expires - [clock seconds]}];" } } 4) when HTTP_REQUEST { set version [SSL::cipher version] set cipher [SSL::cipher name] set oldsite [HTTP::host] set encode [b64encode $oldsite] Check for less than TLSv1.2. This prevents SSLv2, SSLv3, TLSv1, and TLSv1.1 (TLSv1.0 is returned as TLSv1 by [SSL::cipher version]). switch -glob $version { "TLSv1.2" { do nothting } default { When browser cannot negotiate at least TLSv1.1 redirect to a unencrypted page with an informational error. Set cache control headers to prevent proxies from caching the response. The cache control headers shouldn't be necessary for a 302, but it doesn't do any harm setting them. HTTP::respond 302 Location "[http://y.y.y.y.com/?](http://y.y.y.y.com/?)$encode" Cache-Control No-Cache Pragma No-Cache Connection Close ` Log details of the SSL handshake and browser user-agent Consider using High Speed Logging instead to improve performance: https://clouddocs.f5.com/api/irules/hsl.html log local0. "[IP::client_addr]:[TCP::client_port]:\ \[SSL::cipher version\]: [SSL::cipher version],\ \[SSL::cipher name\]: [SSL::cipher name],\ \[SSL::cipher bits\]: [SSL::cipher bits],\ U-A: [HTTP::header User-Agent]" } }
Cheers Steve
JG
Cumulonimbus
Cumulonimbus
I have combined all your irules into one:
when CLIENT_ACCEPTED { set static::expires [clock scan "1 year"] } when HTTP_REQUEST { set version [SSL::cipher version] set cipher [SSL::cipher name] set oldsite [HTTP::host] set encode [b64encode $oldsite] Check for less than TLSv1.2. This prevents SSLv2, SSLv3, TLSv1, and TLSv1.1 (TLSv1.0 is returned as TLSv1 by [SSL::cipher version]). switch -glob $version { "TLSv1.2" { do nothing } default { When browser cannot negotiate at least TLSv1.2 redirect to an unencrypted page with an informational error. Set cache control headers to prevent proxies from caching the response. The cache control headers shouldn't be necessary for a 302, but it doesn't do any harm setting them. HTTP::respond 302 Location "http://y.y.y.y.com/?$encode" Cache-Control No-Cache Pragma No-Cache Connection Close return Log details of the SSL handshake and browser user-agent Consider using High Speed Logging instead to improve performance: https://devcentral.f5.com/wiki/iRules.hsl.ashx log local0. "[IP::client_addr]:[TCP::client_port]:\ \[SSL::cipher version\]: [SSL::cipher version],\ \[SSL::cipher name\]: [SSL::cipher name],\ \[SSL::cipher bits\]: [SSL::cipher bits],\ U-A: [HTTP::header User-Agent]" } } set http_uri [string tolower [HTTP::uri]] switch -glob ${http_uri} { "/ib/*" { do nothing } "/robots.txt" { do nothing } "/favicon.ico" { do nothing } "/sitecore*" } { HTTP::respond 301 Location "https://[HTTP::host]" Connection Close return } "/rsabackchannel/hbibservice.svc" { if { [class match [IP::client_addr] equals FynSin_IPs] } { do nothing } else { HTTP::respond 301 noserver Location "https://x.x.x.x.com" Connection Close return } } default { HTTP::respond 301 noserver Location "https://x.x.x.x.com" Connection Close return } } } when HTTP_RESPONSE { Remove all instances of the Server header HTTP::header remove Server Remove all headers starting with x- (i.e. X-Powered-By, X-AspNet-Version, X-AspNetMvc-Version) foreach header_name [HTTP::header names] { if {[string match -nocase x-* $header_name]}{ HTTP::header remove $header_name } } if { [IP::client_addr] starts_with 10. } { Do nothing. } else { HTTP::header insert Strict-Transport-Security "max-age=[expr {$static::expires - [clock seconds]}];" } } when CACHE_RESPONSE { CACHE::expire }
