tbw_90635
Jul 21, 2009Nimbostratus
Integer Property of Monitor Templates
A monitor template configured with interval=5 and timeout=16 was setup on three version of BigIP.
I called_template_integer_property() using the template name and the types: ITYPE_INTERVAL, ITYPE_TIMEOUT, ITYPE_PROBE_NUM_PROBES, ITYPE_PROBE_NUM_SUCCESSES, and ITYPE_PROBE_TIMEOUT
On a BigIP 9.3:
ITYPE_INTERVAL: 5
ITYPE_TIMEOUT: 16
ITYPE_PROBE_NUM_PROBES: null
ITYPE_PROBE_NUM_SUCCESSES: null
ITYPE_PROBE_TIMEOUT: null
Result: works as expected with correct results
On a BigIP 9.4 (Common partition):
ITYPE_INTERVAL: 0
ITYPE_TIMEOUT: 16
ITYPE_PROBE_NUM_PROBES: 1
ITYPE_PROBE_NUM_SUCCESSES: 1
ITYPE_PROBE_TIMEOUT: 5
Result: seems like the interval value moved to the probe timeout.
On a BigIP 10.0.1 (Common partition):
ITYPE_INTERVAL: 5
ITYPE_TIMEOUT: 0
ITYPE_PROBE_NUM_PROBES: 0
ITYPE_PROBE_NUM_SUCCESSES: 0
ITYPE_PROBE_TIMEOUT: 0
Result: only interval has the correct value
(I'm using the iControl assembles jar supplied by Dev Central with java 1.6)
If find these results confusing. The only one that really works is when using a v9.3 Bigip.
