08-Mar-2021 02:04
McAfee agent can be installed in the Linux Based OS.
Even though F5 is a CentOS-based Linux installation, I understand that the McAfee agent cannot be installed on it.
I am looking for any supporting documentation published by F5 which says that external agents cant be installed on it.
21-Mar-2021 10:50
can't find a clear link, this one sort mentions the risk of trying yourself: https://support.f5.com/csp/article/K41211285 - If you upgrade 3rd party software components only and having issue, clean install BIG-IP may be required.
if you need to know for sure contact F5 support.
