Insert Original HTTP_REFERER into Header iRule
jonathanw84
Cirrus
Cirrus
Hello,
I need to get the HTTP_REFERER header inserted into an environment I have set up. The environment is set up as a reverse proxy with URI translation in both directions. The issue is this:
A request comes into test.server.com/test and is translated to test1.server.com/test. The HTTP_REFERER header shows test1.server.com instead of the original URL. Is there a way to change this?
Thanks!
1 REPLY 1
cjunior
Nacreous
Nacreous
Hello,
Far as I know, it works when we mark option "Rewrite Headers" on "Request Settings" that include all headers.
Is your profile rewriting all headers except from referer?
Regards.
