HY_37629's avatar
HY_37629
Jul 22, 2009
Import SSL from iplanet to LTM?
I need to move certificate from an iplanet server to the LTM. I have to .db files from iplanet. How do I import them to the LTM?
Thanks for your help!
  • Hi,
    Try searching on AskF5.com for convert certificate. LTM expects the cert/key to be in PEM format. I believe iPlanet uses PKCS12 format to store certs/keys. You can use standard openssl commands to do the conversion.
    Aaron
