Technical Forum
iControl - Run and fetch APM Reports
AP
Is it possible to run and download APM reports via iControl? Either JSON or CSV would be fine.
I've had a play around with the /mgmt/tm/apm/report/ endpoint, however this seems to only give some basic properties of the report as opposed to actually generating and fetching a report.
I've also looked around DevCentral but haven't found any discussions on this.
If not iControl, is another method available? I did see this thread (https://devcentral.f5.com/questions/apm-reporting-by-tmsh) regarding TMSH. An RFE was mentioned, however it was apparently still open as of 2015. (ID 413709 - Need command-line based reporting capabilities with CSV results (or scheduling of reports). I've already played around with TMSH and couldn't find anything useful.
Thanks, Andrew
0 REPLIES 0
