Fred1979's avatar
Fred1979
Oct 30, 2020
iControl REST filter from subcollections
I want to find where some node is used in different pool in my bigIp
so i did something like that
curl -sku admin:pass https://<ip>/mgmt/tm/ltm/pool?\&expandSubcollections=true\&\$select=name,partition,membersReference/items/name\&\$filter=membersReference/items/name%20eq%20myServerName| jq
 "code": 400,
 "message": "Query parameter $filter has invalid value membersReference/items/name eq myServerName.",
 "errorStack": [],
 "apiError": 1
someone does know how to make a filter on subCollection variable
  • Hello Fred.
    Check this:
    https://devcentral.f5.com/s/question/0D51T000077D581/icontrol-rest-filtering-by-anything-other-than-partition
    Regards,
    Dario.
  • I dont think there's an option for this. from the guide its application for partition alone. Refer below,
    Parameter Description
    Specifies an administrative partition to query for a result set. This parameter filters
    the result set by partition name and does not fully implement the corresponding
    $filter
    OData query parameter. The asm module fully implements the OData query
    parameter
    But as a workaround, you can use the jq and do the select filter to extract the pool name for a given node name.
