22-Feb-2022 14:39
Hello
I would like to create several remote role groups on few devices using script so i decided to take a look on icontrol rest api. I got authentication token and then tried to list "remote role groups" using:
curl -sk https://ip_mgmt_f5/mgmt/tm/auth/remote-role -H "X-F5-Auth-Token: Generated_Token"
In the output there's no created earlier "remote role groups" from GUI (System/Users/remote role groups"
(version 14.1.4.4)
Maybe icontrol api is not fully implemented regarding remote roles ?
Best Regards
T.
22-Feb-2022 16:08
Great question! The interface you are looking for is: /mtmt/tm/auth/remote-role/role-info. Here's an example:
curl -X POST \
'https://ltm3.test.local/mgmt/tm/auth/remote-role/role-info' \
--header 'Accept: */*' \
--header 'User-Agent: Thunder Client (https://www.thunderclient.io)' \
--header 'Content-Type: application/json' \
--header 'Authorization: Basic YWRtaW46YWRtaW4=' \
-d '{"name": "ops", "attribute": "F5-LTM-User-Info-1=ops", "console": "%F5-LTM-User-Console", "lineOrder": 3, "role": "%F5-LTM-User-Role", "userPartition": "%F5-LTM-User-Partition"}'
And a get returns my other 2 roles in addition to this newly created one:
curl -X GET \
Response:
"kind": "tm:auth:remote-role:role-info:role-infocollectionstate",
"selfLink": "https://localhost/mgmt/tm/auth/remote-role/role-info?ver=15.1.2.1",
"items": [
"kind": "tm:auth:remote-role:role-info:role-infostate",
"name": "/Common/adm",
"fullPath": "/Common/adm",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/auth/remote-role/role-info/~Common~adm?ver=15.1.2.1",
"attribute": "F5-LTM-User-Info-1=adm",
"deny": "disabled",
"lineOrder": 1,
"userPartition": "%F5-LTM-User-Partition",
"userPartitionReference": {
"link": "https://localhost/mgmt/tm/auth/partition/%25F5-LTM-User-Partition?ver=15.1.2.1"
"name": "/Common/appEd",
"fullPath": "/Common/appEd",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/auth/remote-role/role-info/~Common~appEd?ver=15.1.2.1",
"attribute": "F5-LTM-User-Info-1=appEd",
"deny": "disabled",
"lineOrder": 2,
"name": "/Common/ops",
"fullPath": "/Common/ops",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/auth/remote-role/role-info/~Common~ops?ver=15.1.2.1",
"deny": "disabled",
"lineOrder": 3,
