Nick_125581's avatar
Nick_125581
Aug 20, 2013
iControl 500 Can't connect
I am new to iControl so I figured I would download the windows iControl SDK version 11.1 and try to use the SystemServices.pl perl file to connect to our internal F5. I am running Strawberry Perl on a Win 7 64bit machine. When I run the following command: "install dir"\perl5.16.3 SystemServices.pl "host IP address" "host port" "Uid" "Pwd". I get the following error: 500 Can't connect to "host IP address":"host port" at SystemServices.pl line 82
Below is the script that I am running from the SDK, and Line 82 is the following line: $soapResponse = $soap->get_all_service_statuses();
Wondering if anyone can help with the error I am seeing! Also if I use a Web browser I can get to the following url with no issues: https://"host IP address":"host port"/iControl/iControlPortal.cgi?WSDL=System.Services
!/usr/bin/perl
 The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
 Software Development Kit for iControl"; you may not use this file except in
 compliance with the License. The License is included in the iControl
 Software Development Kit.
 Software distributed under the License is distributed on an "AS IS"
 basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
 the License for the specific language governing rights and limitations
 under the License.
 The Original Code is iControl Code and related documentation
 distributed by F5.
 The Initial Developer of the Original Code is F5 Networks,
 Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
 Inc. All Rights Reserved.  iControl (TM) is a registered trademark of F5 Networks, Inc.
 Alternatively, the contents of this file may be used under the terms
 of the GNU General Public License (the "GPL"), in which case the
 provisions of GPL are applicable instead of those above.  If you wish
 to allow use of your version of this file only under the terms of the
 GPL and not to allow others to use your version of this file under the
 License, indicate your decision by deleting the provisions above and
 replace them with the notice and other provisions required by the GPL.
 If you do not delete the provisions above, a recipient may use your
 version of this file under either the License or the GPL.
use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
BEGIN { push (@INC, ".."); }
use iControlTypeCast;
 Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
    $sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
 die ("Usage: SystemServices.pl host port uid pwd\n");
 Transport Information
sub SOAP::Transport::HTTPS::Client::get_basic_credentials
   return "$sUID" => "$sPWD";
$soap = SOAP::Lite
   -> uri('urn:iControl:System/Services')
  -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $soap->transport->https_request->header
  'Authorization' =>
     'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
&getServiceStatuses();
sub getServiceStatuses
    print "==========================================================\n";
   print "System Services\n";
  print "------------------\n";
  if ( $soapResponse->fault )
       my $faultcode = $soapResponse->faultcode;
       my $faultstring = $soapResponse->faultstring;
       $sshd_status = "FAULT : $faultcode : $faultstring";
   else
       my @ServiceStatusSeq = @{$soapResponse->result};
        foreach my $ServiceStatus (@ServiceStatusSeq)
           $service = $ServiceStatus->{"service"};
         $status = $ServiceStatus->{"status"};
           print "$service : $status\n";
