14-Dec-2022 08:06
GTM type A and AAAA wideip generate a json file, like LTM NetworkMap
At present, use python f5-sdk, only type A wideip has been written. GTM works in Common partition testing. The configuration format generated by AS3 has not been test and adapted, because its config seems to work in /partition/folder/config, unlike /Common/config
"wideips": [
"enabled": true,
"name": "pay.bestpay-gtm.189.cn",
"partition": "Common",
"wideip_type": "A",
"poolLbMode": "round-robin",
"persistence": "disabled",
"pools": [
"name": "gslb_pool_bestpay_ctc_v4",
"order": 0,
"ratio": 1,
"loadBalancingMode": "round-robin",
"alternateMode": "none",
"fallbackMode": "none",
"fallbackIp": "any",
"Members": [
"Member": "/Common/vs_ctc_97_22",
"Member Order": 0,
"Member Address": "58.213.97.22",
"Service Port": "80",
"Translation Address": "none",
"Translation Service Port": 0
"Member": "/Common/vs_ctc_97_23",
"Member Order": 1,
"Member Address": "58.213.97.23",
"enabled": true,
"name": "www.163.com",
"wideip_type": "A",
"pools": [
"order": 0,
"ratio": 1,
"Members": [
"Member Order": 0,
"Member Order": 1,
"disabled": true,
"name": "www.as3.com",
"wideip_type": "A",
"aliases": [
"mapi.bestpay.com.cn"
"iRules": [
"/Common/edns_wideip_test"
"enabled": true,
"name": "www.bestpay.com.cn",
"wideip_type": "A",
"poolLbMode": "topology",
"pools": [
"name": "gslb_pool_bestpay_cmcc_v4",
"order": 2,
"ratio": 1,
"Members": [
"Member": "/Common/vs_cmcc_99_22",
"Member Order": 0,
"Member Address": "58.213.99.22",
"Member": "/Common/vs_cmcc_99_23",
"Member Order": 1,
"Member Address": "58.213.99.23",
"order": 0,
"ratio": 1,
"Members": [
"Member Order": 0,
"Member Order": 1,
"name": "gslb_pool_bestpay_cuc_v4",
"order": 1,
"ratio": 1,
"Members": [
"Member": "/Common/vs_ctc_98_22",
"Member Order": 0,
"Member Address": "58.213.98.22",
"Member": "/Common/vs_ctc_98_23",
"Member Order": 1,
"Member Address": "58.213.98.23",
"enabled": true,
"name": "www.gslb.xuwen.com",
"wideip_type": "A",
"pools": [
"name": "gslb_pool_ctc_v4",
"order": 0,
"ratio": 1,
"loadBalancingMode": "global-availability",
"fallbackMode": "return-to-dns",
"Members": [
"Member": "/Common/vs_ctc",
"Member Order": 0,
"Member Address": "58.213.97.84",
"Member": "/Common/vs_cuc",
"Member Order": 1,
"Member Address": "58.240.114.130",
15-Dec-2022 01:06
Python f5-sdk send a GET request to GTM in the form of ~partition~name, but the format of the GET request for the AS3 published wideip should be ~partition~Application~name, so when retrieving the AS3 published wideip, the URL constructed will report HTTP 404. After reading the error source code icontrol\session.py There is a function def _ validate_ name_ partition_ Subpath (element):
def _validate_name_partition_subpath(element):
# '/' and '~' are illegal characters in most cases, however there are
# few exceptions (GTM Regions endpoint being one of them where the
# validation of name should not apply.
if '~' in element:
error_message =\
"instance names and partitions cannot contain '~', but it's: %s"\
% element
raise InvalidInstanceNameOrFolder(error_message)
the determination of whether the name carries the character ~ will cause the structure of AS3 name=i.subPath + '~' + i.name doesn't work.
so delete the judgment of ~ will generate a GTM Wideip NetworkMap json
"wideips": [
"enabled": true,
"name": "www.gslb.bank.com",
"wideip_type": "A",
"lastResortPool": "",
"fullPath": "/Common/www.gslb.bank.com",
"pools": [
"name": "gslb_pool_test",
"order": 0,
"ratio": 1,
"fullPath": "/Common/gslb_pool_test",
"alternateMode": "round-robin",
"Members": [
"Member": "/Common/vs_sideband",
"Member Order": 0,
"Member Address": "200.1.1.200",
"aliases": [
"another.example*"
"enabled": true,
"subPath": "Application",
"name": "example.edu",
"partition": "Example_Tenant",
"wideip_type": "A",
"poolLbMode": "ratio",
"fullPath": "/Example_Tenant/Application/example.edu",
"pools": [
"name": "testPool",
"order": 0,
"ratio": 1,
"fullPath": "/Example_Tenant/Application/testPool",
"Members": []
"enabled": true,
"name": "example.as3.io",
"partition": "example2Tenant",
"wideip_type": "A",
"fullPath": "/example2Tenant/Application/example.as3.io",
"pools": [
"name": "testPoolA",
"order": 0,
"ratio": 1,
"fullPath": "/example2Tenant/Application/testPoolA",
"Members": [
"Member": "0",
"Member Order": 0,
"Member Address": "2.2.3.8",
"Service Port": "5050",
"Member": "2",
"Member Order": 1,
"Member Address": "2.2.3.9",
"enabled": true,
"wideip_type": "AAAA",
"fullPath": "/example2Tenant/Application/example.edu",
"pools": [
"name": "testPoolAAAA",
"order": 0,
"ratio": 1,
"fullPath": "/example2Tenant/Application/testPoolAAAA",
"Members": [
"Member": "1",
"Member Order": 0,
"Member Address": "2001:db8:85a3::8a2e:370:7334",
"Service Port": "5051",
"Member": "3",
"Member Order": 1,
"Member Address": "2001:db8:85a3::8a2e:370:1337",
"Service Port": "5052",
15-Dec-2022 16:19
I know we are no longer doing external development on the sdk, but let me ask someone internal to see if there is a way without development to accomplish what you're looking for.
15-Dec-2022 20:48
Thanks for your reply. BIGIP's built-in Statistics>>Dashbord>>DNS>>Wide IPs, shows that when the wideip goes to gtm pool members, the pool member name is displayed, but the pool members address and service port are not displayed.
Now, i can use python f5 sdk to obtain the json of the type A and AAAA data of the GTM wideip. It supports retrieving the AS3 published wideip. However, to achieve tree like visual display like AppViewX, i must learn some front-end programming languages such as Vue.js to do html visual display
15-Dec-2022 22:47
ah..so the data collection part is fine now and you are just sharing the success on that front, but the challenge going forward is using the data to visualize it?
@Patrik_Jonsson and @TimRiker wrote a front-end for stats for LTM, not sure they have GTM support or aspirations, but maybe their work can inspire yours?
https://community.f5.com/t5/codeshare/big-ip-report/ta-p/285134
15-Dec-2022 23:44
We do not support GTM (yet). It's been requested many times though. Might be something for 2023. 🙂
