07-Nov-2023 07:01
Hello all,
I am trying to set telemetry
But when I try the GET request as per :
https://clouddocs.f5.com/products/extensions/f5-telemetry-streaming/latest/quick-start.html
"code": 404,
"message": "",
"referer": "10.91.aaa.bbb",
"errorStack": []
The logfile restjavad.0.log shows :
[I][22139][07 Nov 2023 14:53:54 UTC][ForwarderPassThroughWorker] {"user":"tmos/<username>","method":"GET","uri":"http://localhost:8100/mgmt/tm/auth/user/<user>,"status":404,"from":"10.91.aaa.bbb"}
Anyone an idea what I must be doing wrong?
Re
Solved! Go to Solution.
07-Nov-2023 11:58
That looks like your package is missing. This will happen after upgrades of BIG-IP, the configuration is stored in a data-group so all you need to do is just reinstall the TS package.
https://clouddocs.f5.com/products/extensions/f5-telemetry-streaming/latest/installation.html
07-Nov-2023 11:58
