TJ_Vreugdenhil
Cirrus
Aug 20, 2010HTTPS 1.1 Custom Monitor using receive string
Hello F5 ADV Community:SOL3224 to create a custom HTTPS monitor for 10.1.0 I switched over to a basic TCP monitor, but we are still seeing the syslog errors reported by voltage. I would like to try to craft a HTTPS monitor to look for a specific string of text, and try to stay away from any type of java connection.
I am running into a issue with a custom HTTPS monitor. A voltage server I have this monitor assigned to, is reporting syslog 'java servlet errors'. I have followed
Custom HTTPS monitor:
defaults from https
send "GET / HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
Do you think the following HTTPS monitor looks right, and would meet my needs, or would you suggest something different?
SEND STRING:
send "GET / HTTP/1.1\r\nHost: voltage-ps-0000.xxxxxxxx.com/login Close\r\n\r\n
RECEIVE STRING:
Email Encryption Provided by Voltage SecureMail
Thanks!
-Tj
- Hamish
Cirrocumulus
Hi WHPH...
Your host: header should just have the FQDN in it... And nothing else. You've got a URI appended to it... I'd make the monitor SEND stringGET /login HTTP/1.1\r\nhost: voltage-ps-0000.domain.com\r\nConnection: close\r\n\r\n
although the connection close shouldn't be needed because the F5 will close it anyway. The actual URI required (I've use /login above) is going to depend on exactly what the voltage server is expecting... It might be required to snoop the URI's being sent and if any other headers are required to complete the request properly.
H
