Karlsen_58024's avatar
Karlsen_58024
Nov 28, 2012
HTTP Redirection iRules
A customer wanted a new web solution and chose Big-IP 3900 to use as a load balancer. They want to migrate from the existing environment to the new one with as little downtime / 404 errors as possible by redirecting old links to the corresponding site in the new environment.
This has led me to create a ton of redirection rules. I am pretty new to Big-IP, so I would like to know what the best practices are around handelig a lot of URIs. This is how I solved it:
if { ([string tolower [HTTP::host]] contains "example.com") and [HTTP::uri] contains "/thisisanoldsite" } {
HTTP::redirect "https://www.example.com/this/is/the/equivilant/site"
if { ([string tolower [HTTP::host]] contains "example.com") and [HTTP::uri] contains "/hey/whatsup.aspx" } {
HTTP::redirect "https://www.example.com/abc/def/example.aspx"
if { ([string tolower [HTTP::host]] contains "example.com") and [HTTP::uri] contains "/page206.aspx" } {
HTTP::redirect "https://www.example.com/subsite/URI/page.aspx"
if { ([string tolower [HTTP::host]] contains "example.com") and [HTTP::uri] contains "/AboutThisPage" } {
HTTP::redirect "https://www.example.com/About/Page.aspx"
This rule is applied on the HTTP Virtual Server. As you can see, everything is redirected to https://, so this iRule will only be applicable on the users first request.
This is just a small part of it. The complete rule contains about 1200 URIs, devided in two seperate iRules.
Can this be changed into something a little less complex? Using switch insted of if's? I would also like if these rules replied with a HTTP 301 Permanently moved status code. Should I replace every HTTP::redirect with HTTP::respond 301 location ?
In advance, thank you.
Regards,
Martin
  • what about this one?
    [root@ve11a:Active:Changes Pending] config  tmsh list ltm virtual bar
    ltm virtual bar {
        destination 172.28.19.252:443
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        rules {
            myrule
        snat automap
        vlans-disabled
    [root@ve11a:Active:Changes Pending] config  tmsh list ltm data-group internal redirection_class
    ltm data-group internal redirection_class {
        records {
            /AboutThisPage {
                data /About/Page.aspx
            /hey/whatsup.aspx {
                data /abc/def/example.aspx
            /page206.aspx {
                data /subsite/URI/page.aspx
            /thisisanoldsite {
                data /this/is/the/equivilant/site
        type string
    [root@ve11a:Active:Changes Pending] config  tmsh list ltm rule myrule
    ltm rule myrule {
       if { [string tolower [HTTP::host]] equals "example.com" } {
          if { [class match -- [HTTP::uri] equals redirection_class] } {
             HTTP::respond 301 noserver Location "https://www.example.com[class match -value [HTTP::uri] equals redirection_class]" Connection Close
    [root@ve11a:Active:Changes Pending] config  curl -Ik https://example.com/AboutThisPage
    HTTP/1.0 301 Moved Permanently
    Connection: close
    Content-Length: 0
  • Brian_Deitch_11's avatar
    Brian_Deitch_11
    Historic F5 Account
    If you are not a fan of multiple IF statements or data groups you could do nested switches:
       switch -glob [ string tolower [HTTP::host]] {
         *example.com* {
            switch -glob [ string tolower [HTTP::uri]] {
              *thisisanoldsite* { HTTP::redirect "https://www.example.com/this/is/the/equivilant/site" }
              */hey/whatsup.aspx* { HTTP::redirect "https://www.example.com/abc/def/example.aspx" }
              */page206.aspx* {  HTTP::redirect "https://www.example.com/subsite/URI/page.aspx" }
              */aboutthispage* {  HTTP::redirect "https://www.example.com/About/Page.aspx"  }
               default { HTTP::respond 301 noserver Location "https://www.example.com" }
         *nextdomain.com* {
              *thisisanoldsite* { HTTP::redirect "https://www.nextdomain.com/this/is/the/equivilant/site" }
              */hey/whatsup.aspx* { HTTP::redirect "https://www.nextdomain.com/abc/def/nextdomain.aspx" }
              */page206.aspx* {  HTTP::redirect "https://www.nextdomain.com/subsite/URI/page.aspx" }
              */aboutthispage* {  HTTP::redirect "https://www.nextdomain.com/About/Page.aspx" }
               default { HTTP::respond 301 noserver Location "https://www.nextdomain.com" }
