emiliocb4_27077's avatar
emiliocb4_27077
Feb 22, 2011
http_post trouble
hi all,
a client send an http post over https. The virtual server close correctly the two-way authentication.
The irule add username and password for basic auth with backend.
username is defined in rule_init
log local0. "in client http ++++++++++++++++++"
foreach aHeader [HTTP::header names] {
log local0. "$aHeader: [HTTP::header value $aHeader]"
log local0. "in input ++++++++++++++++++"
set username $username
set password $username
append password "_pwd!_"
set auth_header "Basic [b64encode $username:$password]"
log local0. "Compongo HEADER HTTP:Authorization con username:$username e password:$password, valore $auth_header"
HTTP::header replace "Authorization" $auth_header
log local0. "Fine http request"
here the output:
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : in client http +++++++++++++++++
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Accept-Encoding: gzip,deflate
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Content-Type:
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : User-Agent: Jakarta Commons-HttpClient/3.1
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Host: 192.168.49.76:9052
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Content-Length: 0
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : in input ++++++++++++++++++
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Compongo HEADER HTTP:Authorization con username:gtw1 e password:gtw1_pwd!_, valore Basic Z3R3MTpndHcxX3B3ZCFf
Feb 22 06:53:25 local/tmm info tmm[5179]: Rule imei_canonical : Fine http request
- the client receive connection reset
- snoop on the backend show the request but it's empty.
any ideas????
thanks a lot
