26-Feb-2022 13:28
Hi.
While trying to access a Http Web Server through F5 LTM and after writing http://xxx.xxx.xxx and access to the login page and put the credentials, the URL changed automatically to https://xxx.xxx.xxx ( without any redirection configuration applied on F5). and I lost the connection to the server as it works on port 80.
What can cause this redirection?
27-Feb-2022 17:52
Hi @Gemini6 ,
If you are not seeing any iRule and/or LTM policy attached to the vServer for redirection, it's likely set on application/server side which might be causing this redirection. You can verify same with app/server owner.
