Technical Forum
How to write irule to ping a host and bring down the pool
shailendra1
I need to create a irule which should ping a host (a VIP on another LTM) , if ping response fails the pool ( irule to be attached to ) is brought down.
1 REPLY 1
Samir
MVP
MVP
iRule work is not to check server status. Create pool with icmp monitor and call via irule and take decision.
