Vinay_12452
Nov 24, 2011How to set HTTPProfile for VirtualServer from Java
Hi..I am a beginner.
I created a VirtualServer using the below code...How can i set the attributes HTTPProfile, FTPProfile, XMLProfile etc to the VirtualServer from java code.
CommonVirtualServerDefinition vsDef = new CommonVirtualServerDefinition(vsName, ipAddress, port, CommonProtocolType.PROTOCOL_TCP);
LocalLBVirtualServerVirtualServerResource vsResource = new LocalLBVirtualServerVirtualServerResource(LocalLBVirtualServerType.RESOURCE_TYPE_POOL, poolName);
LocalLBVirtualServerVirtualServerProfile vsProfile = new LocalLBVirtualServerVirtualServerProfile(LocalLBProfileContextType.PROFILE_CONTEXT_TYPE_ALL, protocol);
virtualServerStub.create({vsdef}, {255.255.255.255}, {vsResource}, {{vsprofile}})
using above code, i could create a VirtualServer. I am getting HTTPProfile, FTPProfile, XMLProfile..etc as 'NONE' in the interface.
How could i set these attributes from java code.
Thanks in advance.
Vinay.
- Vinay_12452
got it. - Once you create the virtual server, you can add profiles with these methods
LocalLB.VirtualServer.add_authentication_profile()
LocalLB.VirtualServer.add_httpclass_profile()
LocalLB.VirtualServer.add_persistence_profile()
LocalLB.VirtualServer.add_profile()
You'll need to call the method depending on the type of profile you are assigning. HTTP, FTP, etc will just be with the standard add_profile() method.
(There are get and remove versions of these methods as well to query and remove the profiles).
The methods are documented here:
http://devcentral.f5.com/wiki/iControl.LocalLB__VirtualServer.ashx
and I wrote a Tech Tip a while back on the Stream Profile. This article shows how to call the add_profile() method to assign a Stream Profile to a Virtual Server:
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/241/iControl-101--18--Stream-Profile.aspx
Hope this helps...
-Joe - Vinay_12452
Thanks alot Joe. Nice article and very much helpful.
