santrim_198688's avatar
santrim_198688
Apr 22, 2015
how to see pool member node connection count history
question: how to see pool member node connection count history? product: LTM virtual edition Is this available out-of-the box default, or has to be added/configured?
thanks, SA
  • LTM does not keep historical statistics for nodes or pool members. To get this type of information you will need to periodically pull the node current connection count over snmp or the iControl API and archive it.
