Technical Forum
Custom Alert Banner
How to recover IPsec Tunnel Pre-Shared Key from configuration ?
IRONMAN
HI,
Any one guide me how to recover the IPSec Pre-shared Key that already configured in F5 LTM+ AFM device!
I can see preshared-key-encrypted in cli config and not sure how to view , need to rebuild it!
1 REPLY 1
Have you asked F5 TAC to do this (you can change the master key after this if you have security concerns)? They may do this if you provide them the master key as they only know how this key is used to encrypt and decrypt passwords:
https://techdocs.f5.com/en-us/bigip-16-0-0/big-ip-secure-vault-administration/f5mku_utility_reference.html
https://support.f5.com/csp/article/K9420
