11-Feb-2020 03:53
hi
i am using bigiq 6.1 with single DCD
i used resizevol /var size(kb) to increase the size of /var
i have assigned all free space to /var
but now i need to increase the size of /var/log
i need to know how to reduce the size of /var , so i can assign freespace to /var/log
11-Feb-2020 22:27
I think shrinking of directories is not supported, increasing the size of the directory is possible using
"tmsh modify sys disk directory <directory name> new-size <new directory size in 1KB blocks>"
12-Feb-2020 00:27
Thank you for sharing your knowledge. Wegmans Login
