10-Nov-2020 01:41
Hi
I need to know how to configure multiple VIP without overwrite the existent.
For now I have this declaration:
"class": "AS3",
"action": "deploy",
"persist": true,
"declaration": {
"class": "ADC",
"schemaVersion": "3.0.0",
"id": "example-declaration-01",
"label": "Sample 1",
"remark": "Simple HTTP application with round robin pool",
"{{ Layer }}": {
"class": "Tenant",
"defaultRouteDomain": 0,
"{{ nomeServizio }}": {
"class": "Application",
"template": "generic",
"class": "Service_HTTP",
"iRules": [{"bigip": "/Common/dynamic_irule"}],
"virtualPort": {{ virtualPort| int }},
"virtualAddresses": ["{{ IPvirtualServer }}"],
"persistenceMethods": ["{{ metodoPersistenza }}"],
"pool": "{{ item.nomePool }}"
"{{ item.nomePool }}": {
"class": "Pool",
"monitors": {{ item.monitor }},
"members": [{
"servicePort": {{ item.membersPort|int }},
"serverAddresses": {{ item.IPmembers|list }}
Now I POST this declaration using extra vars like "metodoPersistenza" etc in order to configure a VIP with external parameters, but if I try to POST this declaration again (with others extra vars) AS3 overwrites the previous VIP...
How can I do to configure multiple VIP in multiple declarations without overwriting the existent configurations?
Thanks in advance
12-Nov-2020 07:26
When you use AS3, you are declaring what final state you want the BIG-IP to be in when the declaration is applied. Don't think of using AS3 to add vips like you would run it 4 times to add 4 vips. You would want to define all the vips in the same declaration and post it at once. All the vips you want to add would be under the tenant: "{{Layer}} in your case.
In your case, add another {{nomeServizio}} to the same declaration.
See here, an example that has 2 virtual servers configured in the same declaration, all under one tenant
https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/declarations/http-services.html#http-and-https-virtual-services-in-one-declaration
