Technical Forum
how to integration vpn mva and owa
herdi
hi expert
i wnat to integration vpn mva and owa the flow like this
i have no idea how to apply the user want ato access email and otp send to sms gateway
thanks
2 ACCEPTED SOLUTIONS
whisperer
Cumulonimbus
Cumulonimbus
I think you need to find a competent partner and procure professional services for architecture design and potential assistance with implementation.
boneyard
MVP
MVP
I agree if @whisperer if you really haven't done something like this before. Reach out to your F5 partner or reseller if you have one.
Else you can search for OWA DUO F5 documents, there are some suggestions here: https://community.f5.com/t5/technical-forum/two-factor-authentication-for-owa-with-f5-apm-and-duo/td...
Beyond that DUO seems to do this also with an own plugin: https://duo.com/docs/owa
2 REPLIES 2
whisperer
Cumulonimbus
Cumulonimbus
boneyard
MVP
MVP
