18-Sep-2020 15:10
Objective:I have an aplication on Azure and I want autenticate this access with F5 APM oAuth.
I have in Azure B2C a list identity provider how Google, etc, but nothing with F5
I create a OpenID identity provider target to F5 , but the response_type is not correct to F5 and denied.
The response_type that azure send is "code" I need intercept this request and change to "code token"
How do it?
