How to enable response logging in WAF
Sayali
Altocumulus
Altocumulus
Hey..
I am testing WAF features on F5.
Details of my test devices:
Type: Virtual
Ver:  BIG-IP 15.1.0 Build 0.0.31
I am testing some security features and so far able to trigger and see events under Security >> Event Logs >> Application >> Requests.
However, for any event, I cannot see Response data due to "Response logging disabled"
I tried creating new logging profile, but I don't see an option to enable "Response" logging. The only options I see for Application Security event logging profile are various "Request" Types.
I would assume logging Response data would be helpful to investigate certain events and/or decide if they are false positives.
Can someone advise on how to enable that?
Thanks 🙂
1 ACCEPTED SOLUTION
Lidev
MVP
MVP
Hello Sayali,
You need to configure your logging profiles and display the Advanced configuration menu.
After, you could be choose "Response Logging" option .
2 REPLIES 2
Lidev
MVP
MVP
Hello Sayali,
Lidev
MVP
MVP
 , thank's for the upvote, please mark this question as solved 😉
