08-Nov-2022 05:22
I'm wondering how I can create/import certificates (mainly ca bundles) on the BIG-IQ and deploy them to several or all of my BIG-IPs? Under "Configuration" I imported a CA bundle and it will be displayed as "Managed Certificate". But under "Evaluate & Deploy -> Local Traffic & Network" I can choose either:
Is this normal behavior, because just a certificate is not a "real" configuration item?
How can I avieve this?
Thank you!
Regards Stefan 🙂
Solved! Go to Solution.
09-Nov-2022 06:27
I found the solution in the meanwhile. The missing piece were the "Pinning Policies" under "Configuration -> Local Traffic". Here you need to assign your newly created items to one or several BIG-IP devices. This also works fine for simply the certificate file itself. No need to create any additional clientSSL profile.
Once pinned, you can create a Deployment with "Source Scope: Partial Changes" and select the newly created certificate. If you now click on "Find Relavant Devices" all BIG-IP devices will be displayed, where you previously pinned the new certificate. After executing the Deployment the certificate is part of the local configuration of all selected BIG-IP devices.
These steps are also required for any other configuration items created on the BIG-IQ. Before deploying them to the required BIG-IP devices, it needs to be pinned first to them.
Thanks anyway!
Regards Stefan 🙂
08-Nov-2022 06:02 - edited 08-Nov-2022 06:04
Hi @Stefan_Klotz ,
I have not worked with BigIQ before , but maybe there is missing configuration , Please check the below Article https://techdocs.f5.com/en-us/bigiq-8-0-0/managing-big-ip-devices-from-big-iq/ssl-certificates.html
I think you need this section :
09-Nov-2022 01:31
Dear Mohamed,
thanks for your response. As already mentioned the certificate is already managed! But if I check your link again, it seems I need a clientSSL profile. I'll try to make a "dummy" profile and check if this will work then and if this way makes sense to our setup at all.
Regards Stefan 🙂
09-Nov-2022 06:27
Thanks anyway!
Regards Stefan 🙂
