How to customize command line prompt?
Well aware of the
$PS1 variable of the BASH shell, but what variable or configuration file controls the prompt of TMSH?
I would like to make the command prompt of TMSH a bit slimmer - eliminate config-sync status and partition.
1) Bash shell, controlled by PS1 variable
[root@localhost:Active] config
2) TMSH shell - how do I modify this?
root@(localhost)(cfg-sync Active)(/Common)(tmos)
- Hannes_Rapp
Thx to @Jason Rahm and @Mark Crosland.
Here's the answer if anyone else got the same question:
tmsh help cli preference, there is a limited amount of stuff to choose from, no shell out to bash for random commands or similar. root@(d3)(cfg-sync Standalone)(Active)(/Common)(tmos) mod cli preference prompt { Options: } Values: avc-count fully-qualified-host mcp-state user config-sync-status host multi-line user-role current-folder mcp-load-status status root@(d3)(cfg-sync Standalone)(Active)(/Common)(tmos) mod cli preference prompt { avc-count host … }- Georgi__Joe__St
Altostratus
Thank you :), you saved me from digging in docs 🙂
I am using this one, hostname is replaced by FQDN and multy-line:
modify cli preference prompt { user fully-qualified-host config-sync-status status current-folder multi-line } - Packeteer_69831
I've done some research for an answer, which I've not found, so I figured it would be best to use a thread that's mostly similar to what I am trying to achieve.
I wanted to update the TMSH cli so that all users can see the FQDN of the device in the TMSH parameters. We use TACACS for authentication and authorization.
What I have found is that modifying the CLI prompt in TMSH appears to be a "per user" setting as verified when looking in /config/bigip_user.conf
I am trying to work out if there is a way to modify the CLI such that it applies to all users who login, without having to add a specific entry in the .conf file for each user.
We have a large number of users who access BigIP for various things, and users also come and go as well.
Has anyone achieved something like this?
Thanks.
