neeeewbie's avatar
Sep 01, 2022
How to consolidate all tmm connection ?
Hi
I need your help !
env : virtual wire
1. syn packet come into the binding ext10 virtual server
2. syn-ack packet come into the binding  int10 virtual server
so, this connection does not established becuase of processing different tmm
this is working well when I turn off cmp-enable option but, tmm0  can't process all traffic
so, How to consolidate all tmm connection ?
thank you
  • Are you asymetric? It sounds like you're not SNATing to me. Set SNAT to auto-map on the initial VS to test if this works.
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      The problem is that the syn-ack packets are coming in through different virtual servers over different vlans, so riding different tmms.
      I turned off the cmp-enable option in the virtual server, but the tmm usage is high, so I'm looking for another way.
      neeeewbie
      I solved that
      sometimes F5 doesn't make connection when same client address.port input on differennt virtual server in this environment
      so, I changed source translate option to change
      thank you
