how should VS be setup for PCoIP for Horizon
Sherri_Shupert
I set up the VS...for Horizon and seem to running ok but PCoIP both UDP and TCP are not working. how should this have been setup? --Sherri
1 REPLY 1
Did you create a virtual server for this traffic?? See the deployment guide: https://www.f5.com/pdf/deployment-guides/vmware-horizon-view-dg.pdf
Cheers,
Kees
