How is APM variable "xml_broker_virtual__cert" updated?
JG
Cumulonimbus
Cumulonimbus
How are the APM variables "xml_broker_virtual__cert" and "xml_broker_virtual__key" updated, preferably via the Configuration Utility?
We are renewing an SSL certificate, and have found that the old cert and key are referenced by these variables in the configuration file.
How do these variables configuration get updated normally?
1 REPLY 1
JG
Cumulonimbus
Cumulonimbus
I edited the config file bigip.conf manually, and did not experience any adverse impact.
