Wasfi_Bounni's avatar
Wasfi_Bounni
Sep 18, 2019
How does the BIG-IP protect from keyloggers with its Datasafe?
Hi;
How does the BIG-IP protect from keyloggers with its Datasafe? Does it detect the keylogger malware, if so, how?
Kindly
Wasfi
  • Hi Wasfi,
    To protect data login form keylogger malware, the Datasafe using inject main JavaScript as core to encrypt URL login form.
    If malware detection and phishing detection are enabled and then inject main JavaScript is disabled, Malware detection and phishing detection will also be disabled. If it is not enabled, the system does not run any client-side encryption on URL login form.
