16-Oct-2018
03:56
- last edited on
02-Jun-2023
08:13
by
JimmyPackets
Hello Team,
I want to know how to check the concurrent CCU usage in F5 Apm.
Using command " tmsh show /apm profile access" i got the below output
User Session Statistics:total sessions: 174.3K
total established sessions: 131.0K
current active sessions: 99
current pending sessions: 2
current established sessions: 97
sessions terminated due to user logged out: 53.2K
sessions terminated due to admin termination: 0
sessions terminated due to timeout or errors: 120.2K
sessions resulted into allow ending: 131.0K
sessions resulted into deny ending: 1.6K
sessions resulted into redirect ending: 0
sessions resulted into redirect ending with session: 0
requests allowed by ACL: 10.4M
requests denied by ACL: 454.6M
Just want to know in the above output "current established sessions: 97" is the no of ccu used...????
16-Oct-2018
04:52
- last edited on
05-Jun-2023
11:42
by
JimmyPackets
you may try using below commands to check real time CCU usage
(echo -e 'get tmm.license.global_connectivity\r' | nc 127.1.1.2 11211)
or
snmpwalk -v 2c -c public localhost F5-BIGIP-APM-MIB::apmAccessStatCurrentActiveSessions
Hope this help
28-May-2020 11:46
16-Oct-2018 06:35
The full explanation here:
K15032: Determining license limits of the BIG-IP APM system https://support.f5.com/csp/article/K15032
To view the concurrent access sessions, type the following command from the BIG-IP APM command line:
