09-Dec-2020 11:55
I see a spike in network activity but would like to see the top talkers for a given timeperiod. How can I view that info? I am using i2800 on 15.1.2.
Thanks.
Solved! Go to Solution.
09-Dec-2020 21:36
Since you ask for the past, I think its doable with 2 options (from what I know), either with logging using an Irule or using the Analytics (AVR) module.
As you also called netstat, which is a real time data, not of past, I'll share few commands which I use, You can try these options,
Current Connections for a given VIP:
tmsh show sys connection cs-server-addr <VIP> | head -n -1 | tail -n +2 | awk '{print $1}'
You can add more filters like awk, cut, sort, uniq to find top source ip's consuming your respective vip.
Total Connections Count so far:
tmsh show ltm virtual <Virtual-name> | grep -E "Ltm::Virtual Server|Total Connections" | awk 'NR%2{printf "%s ",$0;next;}1' | awk '{print $3","$6}'
Live Connections Count on the box:
tmsh show ltm virtual all | grep -E "Ltm::Virtual Server|Current Connections" | awk 'NR%2{printf "%s ",$0;next;}1' | awk '{print $3","$6}'
Also you can use bigtop command,
bigtop -conn -once
Hope this helps.
09-Dec-2020 16:35
When you say a given period, do you mean in the past or current traffic pattern. If current, you can use tmsh or bigtop commands.
09-Dec-2020
19:21
- last edited on
24-Mar-2022
01:25
by
li-migration
I meant sometime in the past. Also, is there any way on F5 to view client session info like netstat -ap etc?
Do you know how I can get a list of client IP addresses to a virtual server?
09-Dec-2020 21:36
bigtop -conn -once
Hope this helps.
