22-Jul-2016
07:30
- last edited on
04-Jun-2023
00:19
by
JimmyPackets
I'm unable to find anywhere here/documentation/articles anyone that could explain a little bit better the authentication token when you get the response from the Rest.
I'm sending the POST to the Rest, and the Rest is returning the Authentication.
Here is an example:
token : AD2GKZPXKVTE4WKJEQUZTIPOM3
userName : admin
authProviderName : tmos
user : ...
groupReferences : ...
timeout : 1200
startTime : 2016-07-22T09:24:11.808-0500
address : 10.10.10.10
partition : [All]
generation : 1
lastUpdateMicros : 1469197451807722
expirationMicros : 1469198651808000
kind : shared:authz:tokens:authtokenitemstate
selfLink : https://localhost/mgmt/shared/authz/tokens/AD2GKZPXKVTE4WKJEQUZTIPOM3
Does anyone knows what is "lastUpdateMicros", "ExpirationMicros" and what is Timeout actually means ? I'm having several issues in my scripts when I call the Rest and the call just fail. If I try to get a new token the call works. I wonder if could be due the token is expired after is used once. Will the token expire only after 1200 seconds or that is not true ?
22-Jul-2016 07:55
The token will timeout after 1200 seconds. All attempts to increase or remove that have been futile for me.
22-Jul-2016 11:42
Can you do as many calls as you want during this 1200 time window?
22-Jul-2016 11:58
That is my experience. If you create the token every time you call the API, you should get the same token until the 1200 seconds is up. So be sure to always generate the token and insert the token as the header and you'll be able to account for when it expires and becomes a new value.
28-Mar-2018
12:22
- last edited on
02-Jun-2023
09:36
by
JimmyPackets
A different token is generated for every request as far as I checked. Tested on 12.1.2 and 13.0.0. The behaviour may be different in a different version. Please post the version number you tested if you can, so I can verify.
Here's a test one-liner:
for i in `seq 1 30`; do curl -sk -X POST -H "Content-type: application/json" \
https:///mgmt/shared/authn/login \
-d '{"username":";", "password":";", "loginProviderName":"tmos"}' | \
python -m json.tool | fgrep '"token": "' | sort | uniq -c; done
To get a list of currently available tokens, run:
curl -sku admin: https:///mgmt/shared/authz/tokens
29-Apr-2020 06:11
how to remove token? I have some problem with login after bulk of request, I am afraid the number of token has reach maximum .
22-Jul-2016 11:42
22-Jul-2016 11:58
28-Mar-2018
12:22
- last edited on
02-Jun-2023
09:36
by
JimmyPackets
11-Jan-2017
16:51
- last edited on
03-Jun-2023
23:26
by
JimmyPackets
It is possible to modify the timeout once a token is obtained. This is achieved using the PATCH method.
Get a token (from a external auth provider in this example):
curl -s -k -u admin:changeme -X POST -H "Content-Type: application/json" -d '{ "username": "mrajagopal", "password": "changeme1234", "loginProviderName": "tmos"}' https://10.154.170.18/mgmt/shared/authn/login
Update the token with preferred timeout (max: 36000) value using the self-link key provided in the response:
curl -sk https://10.154.170.18/mgmt/shared/authz/tokens/Y43RS3JJLFXFH3FRT4PVZQOUOJ -H "X-F5-Auth-Token: Y43RS3JJLFXFH3FRT4PVZQOUOJ" -X PATCH -d '{"timeout" : 4200}'
The 'lastUpdateMicros' key in the response is the unix timestamp of when this token was modified as we did to adjust the timeout.
While the 'expirationMicros' key is the unix timestamp of when this token will expire.
16-Aug-2023 10:12 - edited 16-Aug-2023 10:37
posted by mistake - please delete
22-Sep-2017
04:26
- last edited on
01-Jun-2023
13:58
by
JimmyPackets
In case you want to use BIG-IQ as REST proxy you are forced to use a token.
Please see Ask F5 article "K04452074: Overview of using the BIG-IQ system authentication token". The token timeout of 300 seconds is hard coded.A token can be requested via REST as shown below.
An object is returned containing a key named "token". The value of token is another object containing the token key and value and other elements. To filter the token string the following syntax might be used on shell:curl -sk -X POST -H "Content-Type: application/json" -d '{"username":"", "password":""}' "https:///mgmt/shared/authn/login" | \
grep -oP '(?<="token":)\{("[^"]*":\s*("[^"]*"|[^",]*|\{[^}]*\}|\[[^]]*\]),?)*\}' | grep -oP '(?<="token":")[^"]*'
27-Sep-2017
15:02
- last edited on
05-Jun-2023
21:42
by
JimmyPackets
For more information on the authentication token, refer to the following documents.
iControl® REST API User Guide Version 13.0, especially the following sections:
BIG-IQ® Systems: REST API Reference
... I know. The docs do not define what
lastUpdateMicros
and ExpirationMicros
fields mean ... but we can certainly guess. Try EpochConvertet. If you are using the python API, try
>>> import time
>>> time.gmtime(1386701529797298/10**6)
time.struct_time(tm_year=2013, tm_mon=12, tm_mday=10, tm_hour=18, tm_min=52, tm_sec=9, tm_wday=1, tm_yday=344, tm_isdst=0)
08-Apr-2018 16:00
Got it. From 13.1.0, the maximum number of authentication tokens a non-admin user can obtain is limited to 100. The default life of a token is 30 min, so after that, you should be able to create a new token. It is recommended to reuse the token to avoid the error.
