jzhyc5_48613
Nov 27, 2012Hotfix HFA-11.2.1.807 from V10 partition?
Hi All,
I have two partitions:
HD1.1 - Running 10.2.3
HD1.2 - Running 11.2.1
Is it possible to apply the version 11 Hotfix file from the active V10 partition or do I need to create an addtional V11 partition (e.g. on HD1.3) and apply the Hotfix to HD1.2 from there?
There in advance.
- nitass
Employee
Is it possible to apply the version 11 Hotfix file from the active V10 partition yes, you can install v11 hotfix to hd1.2 from hd1.1. you may have to control configuration import as described in sol below.
sol11267: Controlling configuration import when performing software installations (10.x)
http://support.f5.com/kb/en-us/solutions/public/11000/200/sol11267.html - jzhyc5_48613
Thanks. Good link and something I may have overlooked ...
