28-Feb-2022 04:39
In Citrix Web Interface and Citrix Storefront it is possible to hide applications from appearing during app ennumeration with some modifications to their configuration files, even when a user has access to those apps. I have a APM Citrix webtop (it is replacing webinterface/storefront) I would like to do the same with. Is there some place I can configure or code I can modify to mask specific apps from appearing on the webtop?
I know it seems like a strange request- but I need to filter a specific app from appearing only through one gateway while allowing it to appear for the same users in another gateway. Long story...hoping there is a way to do this with the webtop.
Thanks!
28-Feb-2022 05:35
Alternately, is there a way to inject some tag in the user's clientname such as can be done with the "OverrideIcaClientname = On" parameter in citrix webinterface/storefront so I can see who is coming in from where?
