Warning: Newer to F5 but really enjoying the experience so far. Trying to get my hands dirty with iRules.
I've been doing a lot of research on the forums and I haven't come across the "golden post" yet that can seem to help me with making an iRule for my problem. I feel like it should be easy using universal persistence but I cannot seem to get it to function. It could be my lack of understanding of how the F5s work internally..
Anyway here goes - Scenario: Request comes into LB with a unique "strID" value in the URI or in the HTTP Header "x-original-url" (if via proxy) - /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit
What I need to have happen is to ensure that when a subsequent request comes into the LB with a URI of similar nature with the SAME strID value -- /some_uri?strID=Asb22332&TimeLimit=180&User=Bob&request=poll
That it goes to the same back-end node so the request is processed on the same node. This should happen very shortly after the first submit, so the persistence can be pretty low (30 seconds or less depending on tests).
Here is my code so far:
set sid [findstr [HTTP::uri] "strID" 7 "&"]
log local0. "findstr output: [findstr [HTTP::uri] "strID" 7 "&"]"
if { $sid ne "" } {
log local0. "In IF statement! > $sid <"
set server [session lookup uie $sid]
log local0. "Server: $server"
if { $server ne "" } {
log local0. "Server Found: $server"
node [getfield $server : 1][getfield $server : 2]
else { persist uie $sid 60 }
The behavior I'm seeing is that it does find the strID value, and it will create a universal persistence record with the ID value. However, if I attempt to change that value, a new record is not created.. ? Also, when I hit F5, I do not see $server resolve, it logs just "Server: "
This makes me think my lookup command doesn't actually find the correct value - or I'm really not understanding session vs persistence.. perhaps I'm making it too complicated?
I would greatly appreciate any assistance with the above scenario! Thank you.
If this happens the LB just sends the request to the same node that the TCP session is tied to - but the iRule still logs as seeing the new strID value. I was confused and expected this to create a new persistence record and load balance the request, but something tells me I would need more logic in my iRule to detach the connection and re-load balance it with a new persistence record.
you can use oneconnect profile. it will do that for you.
The output below shows that a persist record is formed on the first request, but the second does not show up. I'm not sure why it doesn't create a new persist record that is re-load balanced? Does it matter if the source IP or browser session is the same?
Since I am newer to F5 I have been using the f5.http iApp template for setup of the testing. I set the OneConnect setting to "Do not use OneConnect" so I am not as far as I can tell. If you want, I could paste my configuration here for you as well.
I can see the key in the logs as you've indicated, and I also receive the same - here are the logs when using two different strID from the same IP & browser session (just changing the value and sending another request, did this many times in a row and the node never changed):
Jun 8 10:25:16 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb20311211&strTimeLimitInSecs=180&request=poll key: acb20311211 server: 10.64.115.151:80
Jun 8 10:25:30 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211&strTimeLimitInSecs=180&request=poll key: acb211 server: 10.64.115.151:80
`</pre>
When I do the "show ltm persistence persist-records" command, I still receive just one record for the output. I guess I would of expected to see two entries, despite the fact the source browser session and IP are from the same - but because the strID is different, it would instead create a new entry for the new key.
-- From further testing --
I notice that when I send in different strID values from different source IPs it creates a new record - which is more what I would expect whenever the strID value changes.
If I send in the same strID value from two different source IP addresses, it doesn't use the existing record of the first request and instead seems to load balance to a different node - as seen by these logs where I used the same URI from two machines:
Jun 8 10:45:03 test info tmm1[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211211&strTimeLimitInSecs=180&request=poll key: acb211211 server: 10.64.115.151:80
Jun 8 10:45:23 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211211&strTimeLimitInSecs=180&request=poll key: acb211211 server: 10.64.115.150:80
The node IP is different, which isn't what I would of expected. I would expect that the user's request would be directed to the same node to be processed since the strID value matches.
I feel that maybe I am misunderstanding something fundamental on universal persistence and its functionality, but I can't put my finger on it. Thank you again for all of your help!
Edit: sorry for the messed up ampersands etc in the logs - it seems the "edit" functionality on the forum here can blow up my original post!
The more I think about this the more I think maybe I'm confusing session persistence with the idea of tying a request string to a node.
ie.
String ID ABC comes in, load balancer directs to node A
String ID BBC comes in, load balancer directs to node B
String ID ABC comes in again, request is sent to node A
String ID BBC comes in again, request is sent to node B
String ID comes in, load balancer directs to A or B and so on
The more I think about this, it seems more of a String to Node lookup table type solution. The problem here being the string is dynamic and generated for any given request, and follow up requests are essentially polling the status of the original request identified by the String ID. For speed, the hope was to direct these to the same servers so the request is in memory and can be responded to as fast as possible...
Just wanted to update that I discovered where my confusion lied: I was seeing persist records drop out of the persist table and not be re-added because my TCP sessions were still active when I was sending follow up HTTP Requests. So long as I opened a new browser window, it would then create a new persist record due to a new TCP connection.
I tested and verified that two source IPs will get stuck to the same node when a persist record exists for a given strID value. So I realized where my testing was invalid, and this seems to be acting as I would expect now!
The only potential use case that I will need to look into to verify it isn't needed is where a request for a different strID value comes in on the same TCP session. If this happens the LB just sends the request to the same node that the TCP session is tied to - but the iRule still logs as seeing the new strID value. I was confused and expected this to create a new persistence record and load balance the request, but something tells me I would need more logic in my iRule to detach the connection and re-load balance it with a new persistence record.
I'm not sure the above situation needed, so I am going back to our development staff for further clarification on how the requests are coming into the VIP with the application.
After re-reading the Oneconnect article you linked - I now fully understand why I was seeing the behavior - thank you so much for your assistance with this!!
"}},"componentScriptGroups({\"componentId\":\"custom.widget.Beta_Footer\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.Tag_Manager_Helper\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:65716\"],\"name\":\"ForumMessagePage\",\"props\":{},\"url\":\"https://community.f5.com/discussions/technicalforum/help-with-uri-string-based-session-persistence/65716\"}}})":{"__typename":"ComponentRenderResult","html":" "}},"componentScriptGroups({\"componentId\":\"custom.widget.Tag_Manager_Helper\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.Consent_Blackbar\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:65716\"],\"name\":\"ForumMessagePage\",\"props\":{},\"url\":\"https://community.f5.com/discussions/technicalforum/help-with-uri-string-based-session-persistence/65716\"}}})":{"__typename":"ComponentRenderResult","html":""}},"componentScriptGroups({\"componentId\":\"custom.widget.Consent_Blackbar\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"messages({\"constraints\":{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:65716\"}},\"first\":10,\"sorts\":{\"postTime\":{\"direction\":\"ASC\"}}})":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcyNCw2NTcyNA","node":{"__ref":"AcceptedSolutionMessage:message:65724"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null},"totalCount":1},"featuredContentWidget({\"coreNodeId\":\"board:TechnicalForum\",\"instanceId\":\"featuredWidgets.widget.featuredContentWidget-1705956211049\",\"quiltId\":\"ForumMessagePage\"})":{"__typename":"FeaturedContentWidget","messages({\"first\":3})":{"__typename":"MessageConnection","totalCount":2,"edges":[{"__typename":"MessageEdge","node":{"__ref":"TkbTopicMessage:message:340911"}},{"__typename":"MessageEdge","node":{"__ref":"TkbTopicMessage:message:340701"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null}},"lastModified":1745603408966,"lastModifiedUser":{"__ref":"User:user:7"}},"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageListMenu\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageListMenu-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewCard\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewCard-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1744046271000"}],"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"components/customComponent/CustomComponent\"]})":[{"__ref":"CachedAsset:text:en_US-components/customComponent/CustomComponent-1744046271000"}],"message({\"id\":\"message:65724\"})":{"__ref":"AcceptedSolutionMessage:message:65724"},"message({\"id\":\"message:65717\"})":{"__ref":"ForumReplyMessage:message:65717"},"message({\"id\":\"message:65718\"})":{"__ref":"ForumReplyMessage:message:65718"},"message({\"id\":\"message:65719\"})":{"__ref":"ForumReplyMessage:message:65719"},"message({\"id\":\"message:65720\"})":{"__ref":"ForumReplyMessage:message:65720"},"message({\"id\":\"message:65721\"})":{"__ref":"ForumReplyMessage:message:65721"},"message({\"id\":\"message:65722\"})":{"__ref":"ForumReplyMessage:message:65722"},"message({\"id\":\"message:65725\"})":{"__ref":"ForumReplyMessage:message:65725"},"message({\"id\":\"message:340911\"})":{"__ref":"TkbTopicMessage:message:340911"},"message({\"id\":\"message:340701\"})":{"__ref":"TkbTopicMessage:message:340701"},"cachedText({\"lastModified\":\"1744046271000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1744046271000"}]},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Former Member","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"dd-MMM-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":null,"possibleValues":["en-US","de-DE"]},"repliesSortOrder":{"__typename":"InheritableStringSettingWithPossibleValues","key":"config.user_replies_sort_order","value":"DEFAULT","localValue":"DEFAULT","possibleValues":["DEFAULT","LIKES","PUBLISH_TIME","REVERSE_PUBLISH_TIME"]}},"deleted":false},"CachedAsset:pages-1746693049844":{"__typename":"CachedAsset","id":"pages-1746693049844","value":[{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.MvpProgram","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/mvp-program","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.AdvocacyProgram","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/advocacy-program","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp.NonCustomer","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/non-customer","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp.F5Customer","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/f5-customer","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetInvolved","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.Learn","type":"COMMUNITY","urlPath":"/c/how-do-i/learn","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739501996000,"localOverride":null,"page":{"id":"Test","type":"CUSTOM","urlPath":"/custom-test-2","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp.Community","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/community","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.ContributeCode","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/contribute-code","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.Learn.AboutIrules","type":"COMMUNITY","urlPath":"/c/how-do-i/learn/about-irules","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp.F5Support","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/f5-support","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI.GetHelp.SecurityIncident","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/security-incident","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746693049844,"localOverride":null,"page":{"id":"HowDoI","type":"COMMUNITY","urlPath":"/c/how-do-i","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}","userBanned":"We're sorry, but you have been banned from using this site.","userBannedReason":"You have been banned for the following reason: {reason}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:41":{"__typename":"Rank","id":"rank:41","position":18,"name":"Nimbostratus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth\"}"},"rankStyle":"FILLED"},"User:user:159517":{"__typename":"User","id":"user:159517","uid":159517,"login":"tm500_165564","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:41"},"email":"","messagesCount":8,"biography":null,"topicsCount":2,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2019-05-04T17:45:53.000-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:159517"},"Category:category:Forums":{"__typename":"Category","id":"category:Forums","entityType":"CATEGORY","displayId":"Forums","nodeType":"category","depth":1,"title":"Forums","shortTitle":"Forums","parent":{"__ref":"Category:category:top"},"categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:top":{"__typename":"Category","id":"category:top","entityType":"CATEGORY","displayId":"top","nodeType":"category","depth":0,"title":"Top","shortTitle":"Top"},"Forum:board:TechnicalForum":{"__typename":"Forum","id":"board:TechnicalForum","entityType":"FORUM","displayId":"TechnicalForum","nodeType":"board","depth":2,"conversationStyle":"FORUM","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"PUBLISH_TIME","repliesFormat":"threaded"},"tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":true,"tagType":"FREEFORM_AND_PRESET","description":"Ask questions.\r\nDiscover Answers.","title":"Technical Forum","shortTitle":"Technical Forum","parent":{"__ref":"Category:category:Forums"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:zihoc95639"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:Forums"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"theme":{"__ref":"Theme:customTheme1"},"boardPolicies":{"__typename":"BoardPolicies","canViewSpamDashBoard":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","args":[]}},"canArchiveMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","key":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","args":[]}},"canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}},"canManageFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","args":[]}},"canUpdateFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","args":[]}},"canReadNode":{"__typename":"PolicyResult","failureReason":null}},"forumPolicies":{"__typename":"ForumPolicies","canManageFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","args":[]}},"canUpdateFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","args":[]}},"canReadNode":{"__typename":"PolicyResult","failureReason":null}},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zMS0yaUY5MjM3RDI3NzVEQzI1M0U\"}"},"eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/"},"ForumTopicMessage:message:65716":{"__typename":"ForumTopicMessage","uid":65716,"subject":"Help with URI string-based session persistence","id":"message:65716","revisionNum":2,"repliesCount":8,"author":{"__ref":"User:user:159517"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalForum"},"conversation":{"__ref":"Conversation:conversation:65716"},"readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:65716"},"body":"
Hi all
\n
\n
I've been doing a lot of research on the forums and I haven't come across the \"golden post\" yet that can seem to help me with making an iRule for my problem. I feel like it should be easy using universal persistence but I cannot seem to get it to function. It could be my lack of understanding of how the F5s work internally..
\n
Anyway here goes - Scenario: Request comes into LB with a unique \"strID\" value in the URI or in the HTTP Header \"x-original-url\" (if via proxy) - /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit
\n
\n
\n
\n
\n
when HTTP_REQUEST {\n set sid [findstr [HTTP::uri] \"strID\" 7 \"&\"]\n log local0. \"findstr output: [findstr [HTTP::uri] \"strID\" 7 \"&\"]\"\n if { $sid ne \"\" } {\n log local0. \"In IF statement! > $sid <\"\n set server [session lookup uie $sid]\n log local0. \"Server: $server\"\n if { $server ne \"\" } {\n log local0. \"Server Found: $server\"\n node [getfield $server : 1][getfield $server : 2]\n }\n else { persist uie $sid 60 }\n }\n}\n
\n
\n
The behavior I'm seeing is that it does find the strID value, and it will create a universal persistence record with the ID value. However, if I attempt to change that value, a new record is not created.. ? Also, when I hit F5, I do not see $server resolve, it logs just \"Server: \"
\n
\n
","body@stringLength":"2359","rawBody":"
Hi all
\n
\n
\n
\n
\n
\n
\n
\nwhen HTTP_REQUEST {\n set sid [findstr [HTTP::uri] \"strID\" 7 \"&\"]\n log local0. \"findstr output: [findstr [HTTP::uri] \"strID\" 7 \"&\"]\"\n if { $sid ne \"\" } {\n log local0. \"In IF statement! > $sid <\"\n set server [session lookup uie $sid]\n log local0. \"Server: $server\"\n if { $server ne \"\" } {\n log local0. \"Server Found: $server\"\n node [getfield $server : 1][getfield $server : 2]\n }\n else { persist uie $sid 60 }\n }\n}\n\n
\n
\n
\n
","kudosSumWeight":0,"postTime":"2015-06-05T15:30:42.000-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:application delivery","text":"application delivery","time":"2021-06-30T01:48:44.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3wxMHxfTlZffDI","node":{"__typename":"Tag","id":"tag:devops","text":"devops","time":"2011-10-19T17:50:55.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3wxMHxfTlZffDM","node":{"__typename":"Tag","id":"tag:iRules","text":"iRules","time":"2022-01-24T02:29:45.106-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3wxMHxfTlZffDQ","node":{"__typename":"Tag","id":"tag:LTM","text":"LTM","time":"2022-01-24T02:29:45.119-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:65716_2"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":1249},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"Hi all \n Warning: Newer to F5 but really enjoying the experience so far. Trying to get my hands dirty with iRules. \n I've been doing a lot of research on the forums and I haven't come across the \"gol...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcxNw","node":{"__ref":"ForumReplyMessage:message:65717"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcxOA","node":{"__ref":"ForumReplyMessage:message:65718"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcxOQ","node":{"__ref":"ForumReplyMessage:message:65719"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcyMA","node":{"__ref":"ForumReplyMessage:message:65720"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcyMQ","node":{"__ref":"ForumReplyMessage:message:65721"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcyMg","node":{"__ref":"ForumReplyMessage:message:65722"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCw2NTcxNyw2NTcyNA","node":{"__ref":"AcceptedSolutionMessage:message:65724"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Conversation:conversation:65716":{"__typename":"Conversation","id":"conversation:65716","solved":true,"topic":{"__ref":"ForumTopicMessage:message:65716"},"lastPostingActivityTime":"2022-12-21T11:31:40.988-08:00","lastPostTime":"2015-06-11T11:55:46.000-07:00","unreadReplyCount":8,"isSubscribed":false},"ModerationData:moderation_data:65716":{"__typename":"ModerationData","id":"moderation_data:65716","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:65716_2":{"__typename":"Revision","id":"revision:65716_2","lastEditTime":"2022-12-21T11:31:40.988-08:00"},"CachedAsset:theme:customTheme1-1746691843538":{"__typename":"CachedAsset","id":"theme:customTheme1-1746691843538","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"JimmyPackets-512-1702592938213.png","imageLastModified":"1702592945815","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"f5_logo_fix-1704824537976.svg","imageLastModified":"1704824540697","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1600px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_PAGE_CONTENT","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"5px","borderRadius":"5px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"14px","paddingXHero":"42px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-400)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-400-h), var(--lia-bs-gray-400-s), calc(var(--lia-bs-gray-400-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-400-h), var(--lia-bs-gray-400-s), calc(var(--lia-bs-gray-400-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-300)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"NONE","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-primary)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#0C5C8D","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#62C026","blogColor":"#730015","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C20025","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#F3704B","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#EE4B5B","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#491B62","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#0C5C8D","secondary":"#333333","bodyText":"#222222","bodyBg":"#F5F5F5","info":"#1D9CD3","success":"#62C026","warning":"#FFD651","danger":"#C20025","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C20025","#081B85","#009639","#B3C6D7","#7CC0EB","#F29A36"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Inter","fontStyle":"NORMAL","fontWeight":"600","h1FontSize":"30px","h2FontSize":"25px","h3FontSize":"20px","h4FontSize":"18px","h5FontSize":"16px","h6FontSize":"16px","lineHeight":"1.2","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"14px","defaultMessageHeaderMarginBottom":"10px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"10px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"14px","specialMessageHeaderMarginBottom":"10px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"10px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Atkinson Hyperlegible","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.3","fontSizeBase":"15px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"13px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1744046271000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:f5.prod:pages/forums/ForumMessagePage:board:TechnicalForum-1746691841779":{"__typename":"CachedAsset","id":"quilt:f5.prod:pages/forums/ForumMessagePage:board:TechnicalForum-1746691841779","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"featuredWidgets.widget.featuredContentWidget","className":null,"props":{"instanceId":"featuredWidgets.widget.featuredContentWidget-1705956211049","layoutProps":{"layout":"card","layoutOptions":{"useRepliesCount":false,"useAuthorRank":false,"useTimeToRead":true,"useKudosCount":false,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"useCenteredCardContent":false,"useTags":true,"useTimestamp":false,"useBoardLink":true,"useAuthorLink":false,"useSolvedBadge":true}},"titleSrOnly":false,"showPager":true,"pageSize":3,"lazyLoad":false},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"pageSize":5,"pagerVariant":{"type":"loadMore"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":false,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":true,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"lazyLoad":false,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"useTitle":true,"addTags":false,"titleContextVariant":"other","showTabs":false,"style":"compact","panelType":"standard","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","useAuthorLoginLink":true,"useNodeLink":true,"usePreviewMedia":true,"timeStampType":"postTime","useTextBody":true,"useSolvedBadge":false,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":false,"useVideoPreview":false,"portraitClampBodyLines":3,"useCompactSpacing":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":true,"useMessageTimeLink":true,"useAuthorLogin":true}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"custom.widget.Community_Quicklinks","className":null,"props":{"customComponentId":"custom.widget.Community_Quicklinks"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1744046271000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1744046271000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1744046271000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:quiltWrapper:f5.prod:Common:1746691797456":{"__typename":"CachedAsset","id":"quiltWrapper:f5.prod:Common:1746691797456","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":"header.jpg","backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"LEFT_CENTER","lastModified":"1702932449000","__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.GainsightShared","props":{"widgetVisibility":"signedInOnly","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Beta_MetaNav","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"700","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":0.4,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"48px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"0","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-primary)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid #0C5C8D","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"#0C5C8D","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"#0C5C8D"},"links":{"sideLinks":[],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"migrated-link-1","params":{"boardId":"TechnicalForum","categoryId":"Forums"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-2","params":{"boardId":"WaterCooler","categoryId":"Forums"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"Forums"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-4","params":{"boardId":"codeshare","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-5","params":{"boardId":"communityarticles","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"categoryId":"CrowdSRC"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-7","params":{"boardId":"TechnicalArticles","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"article-series","params":{"boardId":"article-series","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"security-insights","params":{"boardId":"security-insights","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-8","params":{"boardId":"DevCentralNews","categoryId":"Articles"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-6","params":{"categoryId":"Articles"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-10","params":{"categoryId":"CommunityGroups"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"migrated-link-11","params":{"categoryId":"F5-Groups"},"routeName":"CategoryPage"}],"linkType":"INTERNAL","id":"migrated-link-9","params":{"categoryId":"GroupsCategory"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-12","params":{"boardId":"Events","categoryId":"top"},"routeName":"EventBoardPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-13","params":{"boardId":"Suggestions","categoryId":"top"},"routeName":"IdeaBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.f5.com/c/how-do-i","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__lQ9Z6","showSearchIcon":false},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"transparent","visualEffects":{"showBottomBorder":false},"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"#222222"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-primary)","linkHighlightColor":"#FFFFFF","visualEffects":{"showBottomBorder":false},"backgroundOpacity":60,"linkTextColor":"#FFFFFF"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-body-color)","items":[{"id":"custom.widget.Beta_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Tag_Manager_Helper","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Consent_Blackbar","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"QueryVariables:TopicReplyList:message:65716:2":{"__typename":"QueryVariables","id":"TopicReplyList:message:65716:2","value":{"id":"message:65716","first":10,"sorts":{"postTime":{"direction":"ASC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:component:custom.widget.GainsightShared-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.GainsightShared-en-us-1746691863249","value":{"component":{"id":"custom.widget.GainsightShared","template":{"id":"GainsightShared","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GainsightShared","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_MetaNav-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_MetaNav-en-us-1746691863249","value":{"component":{"id":"custom.widget.Beta_MetaNav","template":{"id":"Beta_MetaNav","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_MetaNav","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Community_Quicklinks-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.Community_Quicklinks-en-us-1746691863249","value":{"component":{"id":"custom.widget.Community_Quicklinks","template":{"id":"Community_Quicklinks","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Community_Quicklinks","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_Footer-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_Footer-en-us-1746691863249","value":{"component":{"id":"custom.widget.Beta_Footer","template":{"id":"Beta_Footer","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Tag_Manager_Helper-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.Tag_Manager_Helper-en-us-1746691863249","value":{"component":{"id":"custom.widget.Tag_Manager_Helper","template":{"id":"Tag_Manager_Helper","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Tag_Manager_Helper","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Consent_Blackbar-en-us-1746691863249":{"__typename":"CachedAsset","id":"component:custom.widget.Consent_Blackbar-en-us-1746691863249","value":{"component":{"id":"custom.widget.Consent_Blackbar","template":{"id":"Consent_Blackbar","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Consent_Blackbar","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1744046271000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1744046271000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1744046271000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solution","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1744046271000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1744046271000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-components/featured/content/FeaturedContentWidget-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/featured/content/FeaturedContentWidget-1744046271000","value":{"edit":"Edit Featured Content","title":"Featured Content","title@instance:iLVTsW":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1702666903735":"","title@instance:TZsNhL":"","title@instance:featuredWidgets.widget.featuredContentWidget-1702666556326":"","title@instance:featuredWidgets.widget.featuredContentWidget-1717525242793":"","title@instance:featuredWidgets.widget.featuredContentWidget-1705956211049":"","title@instance:featuredWidgets.widget.featuredContentWidget-1717525727595":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1728320145294":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1703882552800":""},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1744046271000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1706288370055":"Content Feed","title@instance:1743095186784":"Most Recent Updates","title@instance:1704317906837":"Content Feed","title@instance:1743095018194":"Most Recent Updates","title@instance:1702668293472":"Community Feed","title@instance:1743095117047":"Most Recent Updates","title@instance:1704319314827":"Blog Feed","title@instance:1743095235555":"Most Recent Updates","title@instance:1704320290851":"My Contributions","title@instance:1703720491809":"Forum Feed","title@instance:1743095311723":"Most Recent Updates","title@instance:1703028709746":"Group Content Feed","title@instance:VTsglH":"Content Feed"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1744046271000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"Forum:board:WaterCooler":{"__typename":"Forum","id":"board:WaterCooler","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:Articles":{"__typename":"Category","id":"category:Articles","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"Articles","nodeType":"category","depth":1,"title":"Articles","shortTitle":"Articles"},"Tkb:board:TechnicalArticles":{"__typename":"Tkb","id":"board:TechnicalArticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"TechnicalArticles","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"Technical Articles","shortTitle":"Technical Articles","parent":{"__ref":"Category:category:Articles"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy\"}"},"description":"F5 SMEs share good practice.","eventPath":"category:Articles/community:zihoc95639board:TechnicalArticles/"},"Tkb:board:DevCentralNews":{"__typename":"Tkb","id":"board:DevCentralNews","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"DevCentralNews","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"DevCentral News","shortTitle":"DevCentral News","parent":{"__ref":"Category:category:Articles"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/"},"Category:category:GroupsCategory":{"__typename":"Category","id":"category:GroupsCategory","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:F5-Groups":{"__typename":"Category","id":"category:F5-Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:CommunityGroups":{"__typename":"Category","id":"category:CommunityGroups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Occasion:board:Events":{"__typename":"Occasion","id":"board:Events","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"occasionPolicies":{"__typename":"OccasionPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Idea:board:Suggestions":{"__typename":"Idea","id":"board:Suggestions","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"ideaPolicies":{"__typename":"IdeaPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:CrowdSRC":{"__typename":"Category","id":"category:CrowdSRC","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"CrowdSRC","nodeType":"category","depth":1,"title":"CrowdSRC","shortTitle":"CrowdSRC"},"Tkb:board:codeshare":{"__typename":"Tkb","id":"board:codeshare","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"codeshare","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"CodeShare","shortTitle":"CodeShare","parent":{"__ref":"Category:category:CrowdSRC"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0\"}"},"description":"Have some code. Share some code.","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/"},"Tkb:board:communityarticles":{"__typename":"Tkb","id":"board:communityarticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:security-insights":{"__typename":"Tkb","id":"board:security-insights","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:article-series":{"__typename":"Tkb","id":"board:article-series","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:341327":{"__typename":"Conversation","id":"conversation:341327","topic":{"__typename":"ForumTopicMessage","uid":341327},"lastPostingActivityTime":"2025-05-16T14:38:25.112-07:00","solved":false},"ForumTopicMessage:message:341327":{"__typename":"ForumTopicMessage","subject":"Long URL Redirecting","conversation":{"__ref":"Conversation:conversation:341327"},"id":"message:341327","revisionNum":1,"uid":341327,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":436158,"login":"gaganashree","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":16},"postTime":"2025-05-15T04:16:44.214-07:00","lastPublishTime":"2025-05-15T04:16:44.214-07:00","readOnly":false},"Conversation:conversation:341233":{"__typename":"Conversation","id":"conversation:341233","topic":{"__typename":"ForumTopicMessage","uid":341233},"lastPostingActivityTime":"2025-05-16T14:27:25.542-07:00","solved":true},"ForumTopicMessage:message:341233":{"__typename":"ForumTopicMessage","subject":"APM Access Policy|SSLVPN | SAML auth questionnaires","conversation":{"__ref":"Conversation:conversation:341233"},"id":"message:341233","revisionNum":1,"uid":341233,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":425888,"login":"M_Saeed","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":81},"postTime":"2025-05-10T14:50:56.107-07:00","lastPublishTime":"2025-05-10T14:50:56.107-07:00","readOnly":false},"Conversation:conversation:341073":{"__typename":"Conversation","id":"conversation:341073","topic":{"__typename":"ForumTopicMessage","uid":341073},"lastPostingActivityTime":"2025-05-16T13:09:38.618-07:00","solved":false},"ForumTopicMessage:message:341073":{"__typename":"ForumTopicMessage","subject":"Azure Virtual Machine Scale Set (VMSS) with F5 LTM","conversation":{"__ref":"Conversation:conversation:341073"},"id":"message:341073","revisionNum":1,"uid":341073,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":421728,"login":"ac89live","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":65},"postTime":"2025-04-30T12:29:33.569-07:00","lastPublishTime":"2025-04-30T12:29:33.569-07:00","readOnly":false},"Conversation:conversation:340467":{"__typename":"Conversation","id":"conversation:340467","topic":{"__typename":"ForumTopicMessage","uid":340467},"lastPostingActivityTime":"2025-05-16T11:27:27.146-07:00","solved":false},"ForumTopicMessage:message:340467":{"__typename":"ForumTopicMessage","subject":"F5 DNS Generic Host","conversation":{"__ref":"Conversation:conversation:340467"},"id":"message:340467","revisionNum":1,"uid":340467,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":106197,"login":"jomedusa","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":69},"postTime":"2025-03-25T09:59:16.349-07:00","lastPublishTime":"2025-03-25T09:59:16.349-07:00","readOnly":false},"Conversation:conversation:340961":{"__typename":"Conversation","id":"conversation:340961","topic":{"__typename":"ForumTopicMessage","uid":340961},"lastPostingActivityTime":"2025-05-16T10:27:45.240-07:00","solved":false},"ForumTopicMessage:message:340961":{"__typename":"ForumTopicMessage","subject":"Which encyrtion algorithm is used when making Kerberos ticket encyrtion.","conversation":{"__ref":"Conversation:conversation:340961"},"id":"message:340961","revisionNum":1,"uid":340961,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":426815,"login":"Ozzy","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":37},"postTime":"2025-04-22T23:26:16.827-07:00","lastPublishTime":"2025-04-22T23:26:16.827-07:00","readOnly":false},"User:user:162824":{"__typename":"User","id":"user:162824","uid":162824,"login":"Anirban","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2019-11-25T08:09:51.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:41"},"messagesCount":13,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:162824"},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zMS0yaUY5MjM3RDI3NzVEQzI1M0U\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bi0zMS0yaUY5MjM3RDI3NzVEQzI1M0U","mimeType":"image/png"},"ForumTopicMessage:message:299870":{"__typename":"ForumTopicMessage","uid":299870,"subject":"Payload string based persistence","id":"message:299870","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:162824"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalForum"},"conversation":{"__ref":"Conversation:conversation:299870"},"moderationData":{"__ref":"ModerationData:moderation_data:299870"},"postTime":"2022-08-12T21:08:21.392-07:00","lastPublishTime":"2022-08-12T21:08:21.392-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":1230},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:299870"},"Conversation:conversation:299870":{"__typename":"Conversation","id":"conversation:299870","solved":true,"topic":{"__ref":"ForumTopicMessage:message:299870"},"lastPostingActivityTime":"2022-08-16T19:43:34.662-07:00","lastPostTime":"2022-08-16T19:43:34.662-07:00"},"ModerationData:moderation_data:299870":{"__typename":"ModerationData","id":"moderation_data:299870","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:299870":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:299870","relatedMessage":{"__ref":"ForumTopicMessage:message:299870"}},"User:user:422246":{"__typename":"User","id":"user:422246","uid":422246,"login":"williamcs","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-02-14T01:41:33.858-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:41"},"messagesCount":9,"kudosGivenCount":1,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:422246"},"ForumTopicMessage:message:318007":{"__typename":"ForumTopicMessage","uid":318007,"subject":"source address persistence maximum session timeout","id":"message:318007","revisionNum":1,"repliesCount":7,"author":{"__ref":"User:user:422246"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalForum"},"conversation":{"__ref":"Conversation:conversation:318007"},"moderationData":{"__ref":"ModerationData:moderation_data:318007"},"postTime":"2023-07-02T08:01:05.579-07:00","lastPublishTime":"2023-07-02T08:01:05.579-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":1323},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:318007"},"Conversation:conversation:318007":{"__typename":"Conversation","id":"conversation:318007","solved":true,"topic":{"__ref":"ForumTopicMessage:message:318007"},"lastPostingActivityTime":"2023-07-03T07:58:43.094-07:00","lastPostTime":"2023-07-03T07:58:43.094-07:00"},"ModerationData:moderation_data:318007":{"__typename":"ModerationData","id":"moderation_data:318007","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:318007":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:318007","relatedMessage":{"__ref":"ForumTopicMessage:message:318007"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzgtTzNNNGh5\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMzgtTzNNNGh5","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:38":{"__typename":"Rank","id":"rank:38","position":15,"name":"Cirrus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzgtTzNNNGh5\"}"},"rankStyle":"FILLED"},"User:user:321952":{"__typename":"User","id":"user:321952","uid":321952,"login":"Yann_Desmarest","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-09-11T01:00:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:38"},"messagesCount":1058,"kudosGivenCount":0,"kudosReceivedCount":6,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:321952"},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0","mimeType":"image/png"},"TkbTopicMessage:message:290977":{"__typename":"TkbTopicMessage","uid":290977,"subject":"URI HASH persistence based on URI depth and string length","id":"message:290977","revisionNum":1,"repliesCount":0,"author":{"__ref":"User:user:321952"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:290977"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:290977"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2016-07-27T13:28:47.000-07:00","lastPublishTime":"2016-07-27T13:28:47.000-07:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":393},"placeholder":false,"originalMessageForPlaceholder":null,"entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:290977"},"Conversation:conversation:290977":{"__typename":"Conversation","id":"conversation:290977","solved":false,"topic":{"__ref":"TkbTopicMessage:message:290977"},"lastPostingActivityTime":"2016-07-27T13:28:47.000-07:00","lastPostTime":"2016-07-27T13:28:47.000-07:00"},"ModerationData:moderation_data:290977":{"__typename":"ModerationData","id":"moderation_data:290977","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:290977":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:290977","relatedMessage":{"__ref":"TkbTopicMessage:message:290977"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:37":{"__typename":"Rank","id":"rank:37","position":14,"name":"Cirrostratus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv\"}"},"rankStyle":"FILLED"},"User:user:29768":{"__typename":"User","id":"user:29768","uid":29768,"login":"hoolio","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-09-08T01:00:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-7.svg?time=0"},"rank":{"__ref":"Rank:rank:37"},"messagesCount":11146,"kudosGivenCount":0,"kudosReceivedCount":13,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:zihoc95639/user:29768"},"TkbTopicMessage:message:283869":{"__typename":"TkbTopicMessage","uid":283869,"subject":"Select pool member based on HTTP query string parameter","id":"message:283869","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:29768"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:283869"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:283869"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2015-03-18T15:15:47.000-07:00","lastPublishTime":"2015-03-18T15:15:47.000-07:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":2252},"placeholder":false,"originalMessageForPlaceholder":null,"entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:283869"},"Conversation:conversation:283869":{"__typename":"Conversation","id":"conversation:283869","solved":false,"topic":{"__ref":"TkbTopicMessage:message:283869"},"lastPostingActivityTime":"2015-11-24T09:57:36.000-08:00","lastPostTime":"2015-11-24T09:57:36.000-08:00"},"ModerationData:moderation_data:283869":{"__typename":"ModerationData","id":"moderation_data:283869","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:283869":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:283869","relatedMessage":{"__ref":"TkbTopicMessage:message:283869"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:28":{"__typename":"Rank","id":"rank:28","position":5,"name":"Employee","color":"C20025","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2\"}"},"rankStyle":"OUTLINE"},"User:user:171720":{"__typename":"User","id":"user:171720","uid":171720,"login":"Lori_MacVittie","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2006-10-17T01:00:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:28"},"messagesCount":1290,"kudosGivenCount":0,"kudosReceivedCount":15,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:171720"},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy","mimeType":"image/png"},"TkbTopicMessage:message:284097":{"__typename":"TkbTopicMessage","uid":284097,"subject":"Sessions and Cookies and Persistence, oh my!","id":"message:284097","revisionNum":1,"repliesCount":6,"author":{"__ref":"User:user:171720"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:TechnicalArticles"},"conversation":{"__ref":"Conversation:conversation:284097"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:284097"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2008-06-04T04:50:00.000-07:00","lastPublishTime":"2008-06-04T04:50:00.000-07:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":2287},"placeholder":false,"originalMessageForPlaceholder":null,"entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:TechnicalArticles/message:284097"},"Conversation:conversation:284097":{"__typename":"Conversation","id":"conversation:284097","solved":false,"topic":{"__ref":"TkbTopicMessage:message:284097"},"lastPostingActivityTime":"2014-09-15T00:00:55.000-07:00","lastPostTime":"2014-09-15T00:00:55.000-07:00"},"ModerationData:moderation_data:284097":{"__typename":"ModerationData","id":"moderation_data:284097","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:284097":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:284097","relatedMessage":{"__ref":"TkbTopicMessage:message:284097"}},"User:user:277508":{"__typename":"User","id":"user:277508","uid":277508,"login":"nitass","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2010-02-03T00:00:00.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS0yNzc1MDgtRnhMUEtI?image-coordinates=0%2C447%2C1536%2C1983"},"rank":{"__ref":"Rank:rank:28"},"entityType":"USER","eventPath":"community:zihoc95639/user:277508"},"ModerationData:moderation_data:65717":{"__typename":"ModerationData","id":"moderation_data:65717","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65717":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:277508"},"id":"message:65717","revisionNum":2,"uid":65717,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65717"},"body":"
i might be lost but can't we just use persist command?
\n
e.g.
\n
\n
configuration\n\nroot@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar\nltm virtual bar {\n destination 172.28.24.10:80\n ip-protocol tcp\n mask 255.255.255.255\n pool foo\n profiles {\n http { }\n tcp { }\n }\n rules {\n qux\n }\n source 0.0.0.0/0\n source-address-translation {\n type automap\n }\n vs-index 20\n}\nroot@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo\nltm pool foo {\n load-balancing-mode least-connections-member\n members {\n 200.200.200.101:80 {\n address 200.200.200.101\n }\n 200.200.200.111:80 {\n address 200.200.200.111\n }\n }\n}\nroot@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux\nltm rule qux {\n when HTTP_REQUEST {\n set uri [HTTP::uri]\n set key [URI::query $uri strID]\n if { $key ne \"\" } {\n persist uie $key\n }\n}\nwhen HTTP_RESPONSE {\n log local0. \"URI: $uri key: $key server: [IP::server_addr]:[TCP::server_port]\"\n}\n}\n\n /var/log/ltm\n\n[root@ve11a:Active:In Sync] config tail -f /var/log/ltm\nJun 6 11:28:19 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\nJun 6 11:28:20 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\nJun 6 11:28:20 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\n\nJun 6 11:28:26 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\nJun 6 11:28:26 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\nJun 6 11:28:27 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\n\nJun 6 11:28:33 ve11a info tmm[30284]: Rule /Common/qux : URI: / key: server: 200.200.200.101:80\nJun 6 11:28:34 ve11a info tmm1[30284]: Rule /Common/qux : URI: / key: server: 200.200.200.101:80\nJun 6 11:28:34 ve11a info tmm[30284]: Rule /Common/qux : URI: / key: server: 200.200.200.111:80\nJun 6 11:28:39 ve11a info tmm1[30284]: Rule /Common/qux : URI: / key: server: 200.200.200.111:80\n\nJun 6 11:28:47 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\nJun 6 11:28:49 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\nJun 6 11:28:50 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb22332&TimeLimit=180&User=Joe&request=submit key: Asb22332 server: 200.200.200.101:80\n\nJun 6 11:28:56 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\nJun 6 11:28:57 ve11a info tmm[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\nJun 6 11:28:57 ve11a info tmm1[30284]: Rule /Common/qux : URI: /some_uri?strID=Asb12345&TimeLimit=180&User=Joe&request=submit key: Asb12345 server: 200.200.200.111:80\n\n
\n
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-05T20:31:10.000-07:00","lastPublishTime":"2022-12-21T11:32:11.586-08:00","metrics":{"__typename":"MessageMetrics","views":1137},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65717","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:65718":{"__typename":"ModerationData","id":"moderation_data:65718","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65718":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:159517"},"id":"message:65718","revisionNum":2,"uid":65718,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65718"},"body":"
Hi Nitass
\n
Thank you for your input!
\n
I did originally have a similar iRule setup to yours but what does your show persistence persist-records output when you change the string?
The output below shows that a persist record is formed on the first request, but the second does not show up. I'm not sure why it doesn't create a new persist record that is re-load balanced? Does it matter if the source IP or browser session is the same?
I hope I'm explaining that clearly.... I think maybe I'm misunderstanding how universal persistence is supposed to work.
\n
Thank you!
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-08T08:16:00.000-07:00","lastPublishTime":"2022-12-21T11:33:00.585-08:00","metrics":{"__typename":"MessageMetrics","views":1156},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65718","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:65719":{"__typename":"ModerationData","id":"moderation_data:65719","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65719":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:277508"},"id":"message:65719","revisionNum":1,"uid":65719,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65719"},"body":"
\n\n
i sent requests with two different keys (i.e. Asb22332 and Asb12345). you can see key in the logs.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-08T08:25:15.000-07:00","lastPublishTime":"2015-06-08T08:25:15.000-07:00","metrics":{"__typename":"MessageMetrics","views":1153},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65719","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:65720":{"__typename":"ModerationData","id":"moderation_data:65720","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65720":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:159517"},"id":"message:65720","revisionNum":2,"uid":65720,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65720"},"body":"
Since I am newer to F5 I have been using the f5.http iApp template for setup of the testing. I set the OneConnect setting to \"Do not use OneConnect\" so I am not as far as I can tell. If you want, I could paste my configuration here for you as well.
\n
I can see the key in the logs as you've indicated, and I also receive the same - here are the logs when using two different strID from the same IP & browser session (just changing the value and sending another request, did this many times in a row and the node never changed):
\n
\n
Jun 8 10:25:16 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb20311211&strTimeLimitInSecs=180&request=poll key: acb20311211 server: 10.64.115.151:80\nJun 8 10:25:30 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211&strTimeLimitInSecs=180&request=poll key: acb211 server: 10.64.115.151:80\n`</pre>\n
\n
\n
When I do the \"show ltm persistence persist-records\" command, I still receive just one record for the output. I guess I would of expected to see two entries, despite the fact the source browser session and IP are from the same - but because the strID is different, it would instead create a new entry for the new key.
\n
-- From further testing --
\n
I notice that when I send in different strID values from different source IPs it creates a new record - which is more what I would expect whenever the strID value changes.
\n
If I send in the same strID value from two different source IP addresses, it doesn't use the existing record of the first request and instead seems to load balance to a different node - as seen by these logs where I used the same URI from two machines:
\n
\n
Jun 8 10:45:03 test info tmm1[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211211&strTimeLimitInSecs=180&request=poll key: acb211211 server: 10.64.115.151:80\n Jun 8 10:45:23 test info tmm[11258]: Rule /Common/URI_LB_Tomcat <HTTP_RESPONSE>: URI: /some_uri?&strID=acb211211&strTimeLimitInSecs=180&request=poll key: acb211211 server: 10.64.115.150:80\n
\n
\n
The node IP is different, which isn't what I would of expected. I would expect that the user's request would be directed to the same node to be processed since the strID value matches.
\n
I feel that maybe I am misunderstanding something fundamental on universal persistence and its functionality, but I can't put my finger on it. Thank you again for all of your help!
\n
Edit: sorry for the messed up ampersands etc in the logs - it seems the \"edit\" functionality on the forum here can blow up my original post!
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-08T08:58:29.000-07:00","lastPublishTime":"2022-12-21T11:33:48.328-08:00","metrics":{"__typename":"MessageMetrics","views":1142},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65720","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:65721":{"__typename":"ModerationData","id":"moderation_data:65721","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65721":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:159517"},"id":"message:65721","revisionNum":2,"uid":65721,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65721"},"body":"
The more I think about this the more I think maybe I'm confusing session persistence with the idea of tying a request string to a node.
\n
\n
ie.\nString ID ABC comes in, load balancer directs to node A\nString ID BBC comes in, load balancer directs to node B\nString ID ABC comes in again, request is sent to node A\nString ID BBC comes in again, request is sent to node B\nString ID comes in, load balancer directs to A or B and so on\n
\n
\n
The more I think about this, it seems more of a String to Node lookup table type solution. The problem here being the string is dynamic and generated for any given request, and follow up requests are essentially polling the status of the original request identified by the String ID. For speed, the hope was to direct these to the same servers so the request is in memory and can be responded to as fast as possible...
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-08T10:01:55.000-07:00","lastPublishTime":"2022-12-21T11:34:34.890-08:00","metrics":{"__typename":"MessageMetrics","views":1151},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65721","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:65722":{"__typename":"ModerationData","id":"moderation_data:65722","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65722":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:159517"},"id":"message:65722","revisionNum":1,"uid":65722,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65722"},"body":"
Just wanted to update that I discovered where my confusion lied: I was seeing persist records drop out of the persist table and not be re-added because my TCP sessions were still active when I was sending follow up HTTP Requests. So long as I opened a new browser window, it would then create a new persist record due to a new TCP connection.
\n
I tested and verified that two source IPs will get stuck to the same node when a persist record exists for a given strID value. So I realized where my testing was invalid, and this seems to be acting as I would expect now!
\n
The only potential use case that I will need to look into to verify it isn't needed is where a request for a different strID value comes in on the same TCP session. If this happens the LB just sends the request to the same node that the TCP session is tied to - but the iRule still logs as seeing the new strID value. I was confused and expected this to create a new persistence record and load balance the request, but something tells me I would need more logic in my iRule to detach the connection and re-load balance it with a new persistence record.
\n
I'm not sure the above situation needed, so I am going back to our development staff for further clarification on how the requests are coming into the VIP with the application.
\n
Thank you again for your help!
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-08T11:38:25.000-07:00","lastPublishTime":"2015-06-08T11:38:25.000-07:00","metrics":{"__typename":"MessageMetrics","views":1152},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65722","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:65724":{"__typename":"ModerationData","id":"moderation_data:65724","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"AcceptedSolutionMessage:message:65724":{"__typename":"AcceptedSolutionMessage","uid":65724,"id":"message:65724","revisionNum":1,"author":{"__ref":"User:user:277508"},"readOnly":false,"repliesCount":1,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:65716"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65724"},"body":"
\n\n
you can use oneconnect profile. it will do that for you.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2015-06-11T06:09:05.000-07:00","lastPublishTime":"2015-06-11T06:09:05.000-07:00","solution":true,"metrics":{"__typename":"MessageMetrics","views":1210},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65724","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwzfDM5OjF8aW50LDY1NzI1LDY1NzI1","node":{"__ref":"ForumReplyMessage:message:65725"}}]},"body@stripHtml({\"removeProcessingText\":true,\"removeSpoilerMarkup\":true,\"removeTocMarkup\":true,\"truncateLength\":200})@stringLength":"203","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:65725":{"__typename":"ModerationData","id":"moderation_data:65725","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:65725":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:159517"},"id":"message:65725","revisionNum":1,"uid":65725,"depth":2,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"AcceptedSolutionMessage:message:65724"},"conversation":{"__ref":"Conversation:conversation:65716"},"subject":"Re: Help with URI string-based session persistence","moderationData":{"__ref":"ModerationData:moderation_data:65725"},"body":"After re-reading the Oneconnect article you linked - I now fully understand why I was seeing the behavior - thank you so much for your assistance with this!!","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"157","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-06-11T11:55:46.000-07:00","lastPublishTime":"2015-06-11T11:55:46.000-07:00","metrics":{"__typename":"MessageMetrics","views":1151},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:65716/message:65725","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:65716"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":false,"useNodeHoverCard":false,"usePreviewSubjectModal":false,"useMessageStatus":false}},"CachedAsset:text:en_US-components/community/Navbar-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1744046271000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","migrated-link-9":"Groups","migrated-link-7":"Technical Articles","migrated-link-8":"DevCentral News","migrated-link-1":"Technical Forum","migrated-link-10":"Community Groups","migrated-link-2":"Water Cooler","migrated-link-11":"F5 Groups","Common-external-link":"How Do I...?","migrated-link-0":"Forums","article-series":"Article Series","migrated-link-5":"Community Articles","migrated-link-6":"Articles","security-insights":"Security Insights","migrated-link-3":"CrowdSRC","migrated-link-4":"CodeShare","migrated-link-12":"Events","migrated-link-13":"Suggestions"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1744046271000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1744046271000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1744046271000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1744046271000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1744046271000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1744046271000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1744046271000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1744046271000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1744046271000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1744046271000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1744046271000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1744046271000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1744046271000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1744046271000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1744046271000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolutionList-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolutionList-1744046271000","value":{"emptyDescription":"No has been message solutions yet"},"localOverride":false},"CachedAsset:text:en_US-components/featured/content/AddFeaturedContentModal-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/featured/content/AddFeaturedContentModal-1744046271000","value":{"header":"Edit Featured Content","header.description":"Add, remove, or reorder featured content in this widget{nodeType, select, community{} other{ for {nodeTitle}}}.","PageEditor.header":"Edit Sample Content","PageEditor.header.description":"Add, remove, or reorder sample content to preview how your widget will look.\n\nChanges to sample content here will not be saved or published to any page templates.","AddFeaturedContentModal.selectedMessage.label":"Content","AddFeaturedContentModal.selectedMessage.placeholder":"Find content or enter URL","AddFeaturedContentModal.submit":"Save","AddFeaturedContentModal.cancel":"Cancel","AddFeaturedContentModal.selectedMessage.validate.error":"Select a message","AddFeaturedContentModal.selectedMessage.validate.messageLimitCheck.error":"You can feature up to {limit} posts","submitBtn":"Save","previewBtn":"Preview","cancelBtn":"Cancel","failureTitle":"Error - Action Failed","failureMessage":"An unidentified problem occurred while saving featured content. Please try again later.","successTitle":"Success","successMessage":"Widget updated"},"localOverride":false},"CachedAsset:text:en_US-components/featured/content/FeaturedContentMessageList-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/featured/content/FeaturedContentMessageList-1744046271000","value":{"edit":"Edit Featured Content","header":"Featured Content"},"localOverride":false},"User:user:419489":{"__typename":"User","id":"user:419489","uid":419489,"login":"HeidiSchreifels","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-07-15T10:09:37.046-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS00MTk0ODktYU5jVHhK?image-coordinates=0%2C0%2C121%2C120"},"rank":{"__ref":"Rank:rank:28"},"messagesCount":22,"kudosGivenCount":27,"kudosReceivedCount":31,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:zihoc95639/user:419489"},"TkbTopicMessage:message:340911":{"__typename":"TkbTopicMessage","uid":340911,"subject":"The New F5 Certified BIG-IP Administrator Certification Exams Now Live","id":"message:340911","revisionNum":3,"repliesCount":6,"author":{"__ref":"User:user:419489"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:DevCentralNews"},"conversation":{"__ref":"Conversation:conversation:340911"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:340911"},"teaser":"\n
","postTime":"2025-04-23T11:16:38.997-07:00","lastPublishTime":"2025-04-25T10:49:39.663-07:00","images":{"__typename":"AssociatedImageConnection","edges":[{"__typename":"AssociatedImageEdge","cursor":"MjUuM3wyLjF8b3wyNXxfTlZffDE","node":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3\"}"}}],"totalCount":1,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MjUuM3wyLjF8b3w1fF9OVl98NQ","hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98MQ","node":{"__typename":"Tag","id":"tag:101","text":"101","time":"2022-01-24T02:30:16.258-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98Mg","node":{"__typename":"Tag","id":"tag:201","text":"201","time":"2022-01-24T02:33:36.625-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98Mw","node":{"__typename":"Tag","id":"tag:administrator","text":"administrator","time":"2024-04-19T00:36:27.334-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98NA","node":{"__typename":"Tag","id":"tag:announcement","text":"announcement","time":"2021-12-19T07:45:21.000-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98NQ","node":{"__typename":"Tag","id":"tag:BIG-IP","text":"BIG-IP","time":"2022-01-24T02:29:45.031-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":3,"introduction":"","metrics":{"__typename":"MessageMetrics","views":506},"placeholder":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/message:340911"},"Conversation:conversation:340911":{"__typename":"Conversation","id":"conversation:340911","solved":false,"topic":{"__ref":"TkbTopicMessage:message:340911"},"lastPostingActivityTime":"2025-04-28T08:13:10.869-07:00","lastPostTime":"2025-04-28T08:13:10.869-07:00"},"ModerationData:moderation_data:340911":{"__typename":"ModerationData","id":"moderation_data:340911","status":"APPROVED","rejectReason":null},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3","title":"clipboard_image-1-1745603317979.png","associationType":"TEASER","width":610,"height":343,"altText":""},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:1":{"__typename":"Rank","id":"rank:1","position":0,"name":"Admin","color":"C20025","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY\"}"},"rankStyle":"FILLED"},"User:user:354995":{"__typename":"User","id":"user:354995","uid":354995,"login":"Rebecca_Moloney","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2019-05-30T13:15:33.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS0zNTQ5OTUtTW1jMnNa?image-coordinates=38%2C357%2C711%2C1029"},"rank":{"__ref":"Rank:rank:1"},"messagesCount":115,"kudosGivenCount":202,"kudosReceivedCount":165,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":2,"entityType":"USER","eventPath":"community:zihoc95639/user:354995"},"TkbTopicMessage:message:340701":{"__typename":"TkbTopicMessage","uid":340701,"subject":"F5 Academies Are Back – And We’re Coming to a City Near You","id":"message:340701","revisionNum":12,"repliesCount":3,"author":{"__ref":"User:user:354995"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:DevCentralNews"},"conversation":{"__ref":"Conversation:conversation:340701"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:340701"},"teaser":"
The F5 Academy Roadshow is rolling into 19 cities (plus two virtual stops), and if you work with apps, APIs, or infrastructure, this event was built for you.
\n\n
","postTime":"2025-04-14T09:49:34.463-07:00","lastPublishTime":"2025-04-17T10:30:41.891-07:00","images":{"__typename":"AssociatedImageConnection","edges":[{"__typename":"AssociatedImageEdge","cursor":"MjUuM3wyLjF8b3wyNXxfTlZffDE","node":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12\"}"}}],"totalCount":1,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3w1fF9OVl98MQ","node":{"__typename":"Tag","id":"tag:announcement","text":"announcement","time":"2021-12-19T07:45:21.000-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":3,"introduction":"","metrics":{"__typename":"MessageMetrics","views":558},"placeholder":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/message:340701"},"Conversation:conversation:340701":{"__typename":"Conversation","id":"conversation:340701","solved":false,"topic":{"__ref":"TkbTopicMessage:message:340701"},"lastPostingActivityTime":"2025-05-08T23:13:19.696-07:00","lastPostTime":"2025-05-08T23:13:19.696-07:00"},"ModerationData:moderation_data:340701":{"__typename":"ModerationData","id":"moderation_data:340701","status":"APPROVED","rejectReason":null},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12","title":"Academies.jpg","associationType":"TEASER","width":1130,"height":703,"altText":""},"User:user:7":{"__typename":"User","id":"user:7","login":"LiefZimmerman"},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1744046271000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1744046271000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1744046271000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1744046271000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1744046271000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListMenu-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListMenu-1744046271000","value":{"postTimeAsc":"Oldest","postTimeDesc":"Newest","kudosSumWeightAsc":"Least Liked","kudosSumWeightDesc":"Most Liked","sortTitle":"Sort By","sortedBy.item":" { itemName, select, postTimeAsc {Oldest} postTimeDesc {Newest} kudosSumWeightAsc {Least Liked} kudosSumWeightDesc {Most Liked} other {}}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1744046271000","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewCard-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewCard-1744046271000","value":{"gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1744046271000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1744046271000","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1744046271000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1744046271000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"technicalforum","messageSubject":"help-with-uri-string-based-session-persistence","messageId":"65716"},"buildId":"-gVUpXaWnPcjlrLJZ92B7","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"f5","openTelemetryServiceVersion":"25.3.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/featured/content/FeaturedContentWidget/FeaturedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/featured/content/AddFeaturedContentModal/AddFeaturedContentModal.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","../shared/client/components/common/List/GridList/GridList.tsx","./components/messages/MessageView/MessageViewCard/MessageViewCard.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","./components/customComponent/CustomComponentContent/HtmlContent.tsx","./components/customComponent/CustomComponentContent/CustomComponentScripts.tsx"],"appGip":true,"scriptLoader":[]}
