Wade_Miller_113
Nov 12, 2007Nimbostratus
Help with a difficult irule.
This is not http, but rather a proprietary protocol. Here is the scenario.
The first packet of the request comes in with a string identifying the desired slot.
On connect, check a table (probably data group) and if the string is not matched, select arbitrary pool member and persist.
If the string is matched, select specific pool member and persist.
That is easy enough, but they want more.
If the string is unmatched, it must write to the lookup table with the string AND the pool member selected.
The table would need to be flushed every day when the servers are bounced by cron.
