14-Feb-2023 06:02 - edited 14-Feb-2023 11:08
Hello!
I need help making an iRule that does the following:
1 - if the request goes to "/auth" the client's certificate is not validated, but when BIG-IP forwards a request to the API server in the pool, that API server will validate the serverssl profile (mTLS) certificate.
2 - any other request "/", the client's certificate will be validated and if it is not in the "trusted certificate authorities", the request will be answered with 403. If the certificate is validated, the request will be forwarded to the API server, which will validate the serverssl profile certificate.
I found out another iRule similar to the one I need but when I do the request to URI /auth, there's no browser pop-up to select the cliente certificate.
when CLIENT_ACCEPTED {
set session_flag 0
when CLIENTSSL_HANDSHAKE {
if { [SSL::cert count] != 0 } {
log "Client cert is OK; releasing HTTP request."
HTTP::release
if { ![HTTP::uri] starts_with "/auth" } {
log "Certificate required for: [HTTP::uri]"
if { [SSL::cert count] == 0} {
log "No cert found. Holding HTTP request until a client cert is presented..."
HTTP::collect
set session_flag 1
SSL::authenticate always
SSL::authenticate depth 9
SSL::cert mode require
SSL::renegotiate
else {
log "No certificate needed for: [HTTP::uri]"
Can someone help, please?
14-Feb-2023 09:05 - edited 14-Feb-2023 11:05
set session_flag 0
HTTP::release
HTTP::collect
set session_flag 1
SSL::renegotiate
else {
When I make a request for the /auth URI there is no browser pop-up to select the client certificate.
14-Feb-2023 21:49 - edited 15-Feb-2023 07:11
@Andreia You might try the following iRule but I'm not 100% positive if this is the correct iRule so please do some testing prior to implementing this in production to ensure it is working the way you would expect.
when CLIENT_ACCEPTED priority 500 {
set session_flag 0
when CLIENTSSL_HANDSHAKE priority 500 {
HTTP::release
when HTTP_REQUEST priority 500 {
set URI [string tolower [HTTP::uri]]
if { !(${URI} starts_with "/auth") } {
log "Certificate required for: ${URI}"
HTTP::collect
set session_flag 1
SSL::renegotiate
if { [SSL::cert count] > 0} {
if { [SSL::verify_result] == 0 }{
return
set error_string [X509::verify_cert_error_string [SSL::verify_result]]
set error_string "No client certificate provided"
HTTP::respond 403 content "<html>Invalid client certificate: ${error_string}</html>"
log "No certificate needed for: ${URI}"
15-Feb-2023 05:46
Hi, @Paulius !
Thank you for replying! I pasted the iRule in the test environment and the behavior is the same:
no pop-up window on the browser to select the client certificate. (there's a way to make this pop-up does not appear as happens on nginx with the "ssl_verify_client on" line? OK! I'm sorry I'm overlapping subjects! I will not go on with it right now.)
What is leaving me in doubt is because when I do a simple irule, with these same settings in the Profile SSL Client, with the list of certificates selected in the "Trusted Certificate Authorities", it works! But I actually need to handle this URI-related conditional. And if we try to do the opposite: when the request goes to "/auth" it wil turn OFF this client certificate verification? Can you help me with this?
Thanks!
15-Feb-2023 05:52
I did the test again on "In Private" mode. Look what logs reported:
Feb 15 10:48:28 err tmm1[16269]: 01220001:3: TCL error: /Common/irule_auth-opin-dev_v2 <HTTP_REQUEST> - can't read "error_strign": no such variable while executing "HTTP::respond 403 content "<html>Invalid client certificate: ${error_strign}</html>""
Feb 15 10:48:28 info tmm6[16269]: 01220002:6: Rule /Common/irule_auth-opin-dev_v2 <HTTP_REQUEST>: Certificate required for: /xyz/abc/customers/management/health
Feb 15 10:48:28 err tmm6[16269]: 01220001:3: TCL error: /Common/irule_auth-opin-dev_v2 <HTTP_REQUEST> - can't read "error_strign": no such variable while executing "HTTP::respond 403 content "<html>Invalid client certificate: ${error_strign}</html>""
Can you help?
Thank you!
15-Feb-2023 06:02
I fixed the ${error_strign} to ${error_string} and now I'm receving connection reset when I do a request to another URI that is not /auth. For /auth URI goes Ok!
I'm sorry for a lot of answers it's because I'm reporting while I'm doing the tests.
15-Feb-2023 07:00
@Andreia No worries at all. Is it working the way you would expect now? Sorry for the typing error on "error_string" but good job fixing that.
15-Feb-2023 13:59 - edited 15-Feb-2023 13:59
Hi, @Paulius!
Unfortunately not 😞
Now I'm receiving "Connection Reset" on browser.
I will try to do the opposite: do all the configuration on the SSL Client Profile works, and, when the request starts with /auth will disable the need to validate the client certificate.
Wish me luck! LOL
Thanks a lot!
