30-Apr-2021 09:57
Hello All,
I have a scenario where I have to use only one HTTPS Virtual server for multiple applications listening on different ports on different node, for example:
There are 3 servers , Node_X, Node_Y, Node_Z and VIP resolve to ww.abc.com
https://www.abc.com/core ----> https://Node_X:10004/core/
https://www.abc.com/service ----> https://Node_X:10004/service/
https://www.abc.com/ims ----> https://Node_X:10009/ims/
https://www.abc.com/portal ----> https://:Node_Y:10005/portal/
https://www.abc.com/ords----> https://Node_Z:10008/ords/
I created 4 pools as below but didn't attach any pool to the Virtual server:
Pool_X for Node_X - port 10004
Pool_X1 for Node_X - port 10009
Pool_Y for Node_Y - port 10005
Pool_Z for Node_Z - port 10008
I am using the following iRule but is is not working, please help how can I achieve this ?? Can I use policy or re-write policy ??
if { [HTTP::uri] starts_with "/core" } {
use pool Pool_X
} elseif { [HTTP::uri] starts_with "/service" } {
use pool Pool_X
} elseif } [HTTP::uri] starts_with "/ims" } {
use pool Pool_X1
} elseif { [HTTP::uri] starts_with "/portal" } {
use pool Pool_Y
} elseif { [HTTP::uri] starts_with "/ords" } {
use pool Pool_Z
Solved! Go to Solution.
30-Apr-2021
10:40
- last edited on
04-Jun-2023
20:55
by
JimmyPackets
Hi Sulabh Srivastana,
Remove use command.
pool Pool_X
pool Pool_X
} elseif { [HTTP::uri] starts_with "/ims" } {
pool Pool_X1
pool Pool_Y
pool Pool_Z
switch version:
switch -glob [HTTP::uri] {
"/core*" -
"/service*" { pool Pool_X }
"/ims*" { pool Pool_X1 }
"/portal*" { pool Pool_Y }
"/ords*" { pool Pool_Z }
without using pool:
"/core*" -
"/service*" { node 1.2.3.4 10004 }
"/ims*" { node 1.2.3.4 10009 }
"/portal*" { node 5.6.7.8 10006 }
"/ords*" { node 9.10.11.12 10008 }
30-Apr-2021
10:40
- last edited on
04-Jun-2023
20:55
by
JimmyPackets
Remove use command.
pool Pool_X
pool Pool_X
pool Pool_X1
pool Pool_Y
pool Pool_Z
switch version:
"/core*" -
without using pool:
"/core*" -
03-May-2021 11:11
Hi Enes,
Thanks for your response, I tried but none of the given solution is working. Please let me know if I am missing something.
03-May-2021
11:31
- last edited on
04-Jun-2023
20:55
by
JimmyPackets
log local0. "requri0: [HTTP::uri] - cip: [IP::client_addr]"
log local0. "requri1: [HTTP::uri] - cip: [IP::client_addr]"
pool Pool_X
log local0. "requri2: [HTTP::uri] - cip: [IP::client_addr]"
pool Pool_X
log local0. "requri3: [HTTP::uri] - cip: [IP::client_addr]"
pool Pool_X1
log local0. "requri4: [HTTP::uri] - cip: [IP::client_addr]"
pool Pool_Y
log local0. "requri5: [HTTP::uri] - cip: [IP::client_addr]"
pool Pool_Z
Can you investigate the logs on cli and pool stats on gui?
tailf /var/log/ltm | grep requri
03-May-2021 12:17
I can see client IP as my IP (I am the tester) and SNAT IP, the iRule is being executed but traffic is not hitting the pool, no hits on pool.
