Health check on F5 Load Balancer
How people perform the health check on F5 device?
What kind of command or API will be use in order to check the health of F5 device ?
It would be helpful for me if anyone can help me.
Regards
You can use below commands to check status/health of F5 device.
tmsh show sys cpu --- Check cpu status
tmsh show sys connection ---- check current open connections
tmsh show sys memory --- Check memory usage
df -h --- Check memory usage
tmsh show sys hardware --- Check hardware status
tmsh show cm failover-status – Check HA/Failover status
tmsh show sys traffic – Traffic Statistics
tmsh show cm sync-status ---- Check sync status
tmsh show cm traffic-group --- Check Traffic-Groups
uptime --- Check F5 device uptime
tmsh show ltm virtual --- Check connection status on VS
tmsh show sys ha-status --- Check HA status
tmsh show sys service --- Check all services status and up time.
tmsh show sys availability --- Check system availability status
Hope it helps!
Mayur
- Abhinav5656
Thank you very much for the quick reply.
