Bryce_Halkerst1's avatar
Bryce_Halkerst1
Mar 12, 2013
Header insert for lb server ip and tcp port
Working
X-Who-A
when HTTP_RESPONSE {
set server [string range [LB::server] 2 end]
set port [string range [LB::server port] 2 end]
HTTP::header insert "X-Who-A" "AN-$server-$port"
Header output: X-Who-A AN-ommon/Weblogic_Pool 10.193.83.43 7001
Need header output to be AN-83.43-01
Tried the follwoing string logic, but website will not load when applied: Client would like to have this inserted into the header to be able to drill down which server app is having issues. Has anyone add any luck implementing?
Thanks,
Bryce
scan [LB::server] {%d.%d.%d.%d} a b c d
HTTP::header insert "X-Who-A" "AN-$c.$d-$port"
  • e.g.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.252:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve10:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:80 {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
      scan [IP::remote_addr] {%d.%d.%d.%d} a b c d
      HTTP::header insert "X-Who-A" "AN-$c.$d-[TCP::remote_port]"
    [root@ve10:Active] config  curl -I http://172.28.19.252
    HTTP/1.1 200 OK
    Date: Tue, 12 Mar 2013 15:11:03 GMT
    Server: Apache/2.2.3 (CentOS)
    Last-Modified: Sat, 27 Oct 2012 03:22:35 GMT
    ETag: "4183f3-59-f28f94c0"
    Accept-Ranges: bytes
    Content-Length: 89
    Content-Type: text/html; charset=UTF-8
    X-Who-A: AN-200.101-80
  • you may avoid using a and b variables by using asterisk (*).
    rule myrule {
      scan [IP::remote_addr] {%*d.%*d.%d.%d} c d
  • All,
    Not having any issues with the irule outputting the last 2 digits of the server tcp ports. Client changed the ports on the server end, so I need the first 2 digits. See below.
    Thanks,
    Bryce
    Last Digits work great
    rule myrule {
    Tried this logic for the first 2 digits in the header insert. No dice!
    rule myrule {
    scan [IP::remote_addr] {%*d.%*d.%d.%d} a b
    HTTP::header insert "X-Who-A" "AN-$a.$b-[TCP::remote_port]"
