Technical Forum
Hardware Refresh Best Practices
AtulAnand
Altostratus
Altostratus
What is the best ways to ensure the migration of configuration from older hardware to either BIG-IP VE or new hardware ?
  1. UCS with no platform check
  2. SCF - Complete load sys config
  3. SCF manually configuring piece by piece - merging components one by one
I was sceptic with UCS and that carries all network and management IPs along, and in a production environment it may mess up things while performing it.
same with full SCF load, it has so many dependent network and management-ip and route related config, that may not host and may mess up management IP.
2 REPLIES 2
Samir
MVP
MVP
Hardware refresh is not easy task, It require lot of preparations. So, always i suggest to have discussion with F5 PS. Small configuration mismatch/issue will directly impact customer business.
  1. Pre and post traffic confirmation/Manual review
Ref: https://support.f5.com/csp/article/K13132
Lidev
MVP
MVP
Hi AtulAnand,
an great article that will help you make your choice 😉
https://devcentral.f5.com/s/articles/migrating-to-iseries-from-older-platforms-its-about-time-25612
Regards
