HA pair configuration on AWS not working
We are setting F5 HA pair on AWS we have done the configuration on using "Run Config Sync/HA Utility" but its not working. When I again try configure it shows
"Device trust has a configuration that is not supported by the Setup Utility. Please use the Device Management section of the configuration utility to modify discover configsync and/or high availability peers."
1) Configured floating IP on both Internal and external VLAN.
2) Configured internal VLAN as High Availability Network.
3) Configured the failure and unicast for internal VLAN interface and management interface.
4) Added the secondary F5 as peer and created device group for sync-failover using both F5.
5) We are able to access the URL when primary F5 is active, When we do the failure URL is inaccessible.
- James_Thomson
Employee
Have you seen these pieces of information. Because of AWS and L2 networking being different, you cannot set up HA as you usually do.
https://devcentral.f5.com/articles/f5-in-aws-part-1-aws-networking-basics
https://devcentral.f5.com/videos/deploying-a-big-ip-virtual-edition-ha-pair-in-aws
- AnkushP_222309
Hi James,
Thanks for your reply. We have already followed the steps mention in the video, but it didn't work.
do you have nay other option we can try out.
