nanukanu_263047
Feb 25, 2017Nimbostratus
HA Group Failover problem
Im having troubles related with HA failover...
The scenario:
2xVcmps hosts with 2,guests inside. Guests working in Act/Pas
Lacp with 4 ports tied in lacp active mode.
1 HA cable directly attached between devices.
HA Group created with condition of trunk fails in the guest side, no ha configured on hosts.
The problem comes when I disconnect the 4 ports from active unit, I see how change the passive to active state, from F5 seems all OK, but from the outside any network can reach IPs behind the F5...
When i unplug the HA cable the new active unit start to respond the outside petitions...
Any help on this issue?
Regards!
