Technical Forum
GUI Partially Loads
Ryan77777
Altocumulus
Altocumulus
I have a situation where my LTM will not completely load the GUI. After logging in (submitting user/pass), this is what we see. I've attempted to restart http and tomcat to no avail. Version 15.1.0. I have a case open, but they're taking a bit so wanted to see if anybody else has run into this.
1 ACCEPTED SOLUTION
Lidev
MVP
MVP
Hi Ryan,
No errors in /var/log/tomcat/catalina.out ?
What's the level of Management Provisioning (MGMT) ? small?
Regards
4 REPLIES 4
Ryan77777
Altocumulus
Altocumulus
# list /sys httpd
sys httpd {
  auth-pam-idle-timeout 900
  include "FileETag MTime Size"
  max-clients 20
We tried altering the Max Clients as well (K9588), restarted the web services, and that did not resolve.
Ryan77777
Altocumulus
Altocumulus
Also didn't resolve -- K11140735 (clearing pamcache)
Lidev
MVP
MVP
Hi Ryan,
Regards
Ryan77777
Altocumulus
Altocumulus
We ended-up having to reboot it. It came right back up after doing so. We reprovisioned the management module as well (was on small).
